    Bedtemp open circuit at -5°C
    • isotoneundefined
      isotone
      Hi, I am running a separately powered peltier bed system with the duet wifi to get down to -10 to -30 C, when the bedtemp hits -5C I immediately get -273C showing open circuit.
      I have tried many different thermistor types and wiring and checked the disconnected thermistors are giving the correct resistance and not shorting at these low temps, and it always fails at -5.0C exactly, so am thinking this might be a hard minimum setting somewhere but am having no luck finding it.
      thanks for any help and merry christmas 🙂
        It's difficult to tell the difference between a high-resistance thermistor at low temperatures and an open-circuit thermistor. For this reason, RRF treats any temperature below -5C as an open circuit thermistor, on the basis that operating a 3D printer below -5C would be unusual.
        This does not apply to PT100 or PT1000 sensors or thermocouples. So if you need to measure lower temperatures, I suggest you use one of those sensor types.
        It would be possible to measure lower temperatures accurately using a lower resistance thermistor, for example a thermistor that has a resistance of 1K at 25C. I will change the firmware to use a lower temperature limit when using a low resistance thermistor.
        • isotoneundefined
          isotone
          Ah, thanks a lot. It is a research project so hopefully not too many people are doing this... 🙂
          I am amazed and super happy there is an inversion option if I wanted to power any of it off the board tbh!
            Firmware 3.2RC2 which has just been released should allow you to measure below -5C if you use a 1K or 10K thermistor.
            • isotoneundefined
              isotone
              what a Christmas pressie, thanks a lot!
              here is my work if it is of any interest.
