    problem Set Mesh Parameters
    Config Tool
    351
    • konte1978undefined
      konte1978
      hello guys I have a problem that I can't solve by myself, I can't define the space to probe related to the bltouch.
      If I vary the minimum and maximum values x y of the command M557 X24: 290 Y76: 295 S20 I do not get any variation it always starts at the same point above the glass clip.
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @konte1978
        @konte1978 said in problem Set Mesh Parameters:
        there should be no space after the :
        konte1978undefined 1 Reply Last reply Reply Quote 0
          konte1978
          I am attaching my config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Jul 17 2020 20:24:58 GMT+0200 (CEST)
          M550 P" CUBE PRO TRIO" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P4 S1 ; physical drive 4 goes forwards
          M569 P9 S1 ; physical drive 9 goes forwards
          M584 X0 Y1 Z2 E3:4:9 ; set drive mapping
          M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
          M92 X87.35 Y87.43 Z1076.77 E82.09:82.09:82.09 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X15000.00 Y15000.00 Z1200.00 E600.00:600.00:600.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z250.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
          M906 X1500 Y1500 Z800 E1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent (ho modficato la corrente dei motori dell'estrusore da 800 a 1200)
          M84 S30 ; Set idle timeout
          M208 X0 Y0 Z0 S1 ; Imposta valore minimo deli assi
          M208 X290 Y295.3 Z205 ; imposta il valore massimo degli assi ho tolto il valore S0 ALLA FINE DELLA RIGA
          M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M950 S0 C"duex.pwm5" ; creare il servo pin 0 per BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 A10 R0.75 S0.02 ; set Z probe type to bltouch and the dive height + speeds
          G31 P25 X82 Y-50.5 Z2.75 ; impostare il valore del trigger della sonda Z, l'offset e l'altezza del trigger
          M557 X24:290 Y76:295 S20 ; define mesh grid
          ;Piatto riscaldato
          M143 H0 S110 ; set temperature limit for heater 0 to 120C
          ;Estrusore numero 1
          M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S290; set temperature limit for heater 0 to 120C
          ;Estrusore numero 2
          M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H2 S270
          ;Estrusore numero 3
          M308 S3 P"spi.cs3" Y"rtd-max31865" ;M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4725 ; configure sensor 3 as thermistor on pin duex.e2temp
          M950 H3 C"duex.e2heat" T3 ; create nozzle heater output on duex.e2heat and map it to sensor 3
          M143 H3 S270 ; set temperature limit for heater 0 to 120C
          M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          ; Riscaldatore della camera
          M141 H4 ; il riscaldatore 4 è il riscaldatore della camera
          M950 H4 C"duex.e3heat" T4 ; configura l'uscita per il riscaldamento della camera sull pin e della scheda duex
          M308 S4 P"duex.e3temp" Y"thermistor" T100000 B5500 C7.06Ee-8 ; configure sensor 4 as thermistor on pin duex.e2temp
          M143 H4 S70 ; set temperature limit for heater 0 to 120C
          M301 H4 B1 ; utilizzare il controllo bang-bang per il riscaldatore della camera
          M106 P0 C"ESTRUSORI" S0 H3:2:1 T120 ; set fan 0 name and value. Thermostatic control is turned on
          M106 P1 C"NOZZLE" S0 H1:2:3 T45 ; set fan 1 name and value. Thermostatic control is turned on
          M106 P2 C"LUCI LED" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
          M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
          M106 P3 C"VENTOLA 6" S0 H-1 ; set fan 3 name and value. Thermostatic control is turned off
          M950 F4 C"duex.fan7" Q500 ; create fan 4 on pin duex.fan7 and set its frequency
          M106 P4 C"VENTOLA 7" S0 H-1 ; set fan 4 name and value. Thermostatic control is turned off
          M563 P0 S"estrusore 1" D0 H1 F0:1 ; define tool 0
          M563 P1 S"estrusore 2" D1 H2 F0:1 ; define tool 1
          G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
          G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
          M563 P2 S"estrusore 3" D2 H3 F0:1 ; define tool 2
          G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
          G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
          ; Sensori di folamento degli estrusori
          													;se imposto l'ultima S0 disabilita il confronto tra filamento aspetatto e quello realmente estruso,S1 abilita il controllo
          													;valori sensibilità filamneto originale R40:120
          M591 D0 P5 C"e0stop" R5:190 E3.0 S0; ho configurato il filamento del primo estrusore sull'uscita e0stop
          M591 D1 P5 C"connlcd.encb" R5:190 E3.0 S1 ; ho configurato il filamento del secondo estrusore sull'uscita stop10(ECN_B)
          M591 D2 P5 C"e1stop" R5:190 E3.0 S1 ; ho configurato il filamento del terzo estrusore sull'uscita e1stop
          M575 P1 S1 B57600 ;per abilitare lcd paneldue
          M501
            konte1978 @Veti
            @Veti no space left, you could take a look at my config.g. Where am I doing wrong???
            • Vetiundefined
              Veti @konte1978
              delete this line
              how did you arrive at those numbers, they seem odd.
              you have to take into offset when defining the mesh
              if you want to probe at x24 your nozzle would have to go to - 58 which is not allowed from your minimum.
              so your x probing should start at x82
              for y the maximum here is 244.
              you should be getting warnings in the console when probing the mesh telling you about this.
                konte1978
                thank you very much, I think I have solved I changed the values in G31
                • Vetiundefined
                  Veti @konte1978
                  @konte1978
                  the G31 need to be correct or the mesh bed levelling will not work correctly.
                    konte1978 @Veti
                    @Veti said in problem Set Mesh Parameters:
                    I made a mark on the plate where I positioned myself above with the nozzle n ° 1 and then with the bltouch probe, I made the difference between the values indicated on the DRO
