    if clause with choice box
    Duet Web Control
    • medicusdkfzundefined
      medicusdkfz
      is it possible, to have a textbox in DWC with 2 choices for filament a and b. If you choose filament a, then it shall load the mesh for metal sheet a. When you choose filament b -> mesh formetal sheet b.
      Thank you in advance,
      Pierre
      • A Former User?
        A Former User
        afaik closest you get is ok/cancel and some trickery with conditional gcode .. or writing a plugin for dwc
        if you have free inputs you could perhaps key the sheets and use switches or inductive/capacitve sensors to detect the type of sheet?
          jay_s_uk
          why not use the filaments part of DWC to load different mesh files?
          • fcwiltundefined
            fcwilt
            I would use the filament selection feature of DWC for that.
            I have also used dummy fans as text variables (the name) which display in the fan section of DWC. I use macros to set the fan name.
