    G29 - on a Delta how many points?
    • WZ9Vundefined
      WZ9V
      On my Delta I'm getting 141 points using 20mm spacing at 170mm radius. The firmware isn't complaining but am I building to large a mesh?
        You can have up to 442 points on a Cartesian printer with the Series 2 Duets, e.g. 21 x 21 points. On a delta it's still 21 points across the diameter because the grid is represented as a rectangle with inaccessible points not probed.
