    Stall detection?
    • paenian
      paenian last edited by
      I couldn't find much information on the stall detection - I know the drivers support it, but is it triggered/handled in any of the gcode commands?
      In particular I figured one could home until stall, for endstopless homing 🙂
      perhaps G0 X-1000 S3?
      Paul
        The stall detection only works over a limited speed range and it is updated at most once per full microstep. So it wouldn't be accurate enough to home a Cartesian printer.
        EDIT: you can use stall detection to home a Cartesian printer if you don't need the home position to be highly accurate. This is now covered in the wiki.
        It might be possible to use stall detection to home a delta printer if you follow homing with delta calibration using a Z probe. In fact you can do this without stall detection, you just need to reduce the motor current during homing (M913 command) so that the motors don't exert too much force when the hard stops are reached.
