    Help me with dual z motors
    • nirmal2013undefined
      nirmal2013
      I am using duet 2 wifi, 12v PSU and 2 Z motors.
      when i do "G1 H2 Z10" only one motor is rotating & another is making some noise and not rotating. this when in no load condition itself.
      thanks in advance!
      • Vetiundefined
        Veti
        do not use H2 for the testing
        post your config.g
        how are the motors connected.
        what are the specs of the motors
          nirmal2013
          Thanks for your reply...
          Here is my config file:
          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Fri Jan 01 2021 10:57:11 GMT+0530 (India Standard Time)
          M550 P"M4P" ; set printer name
          M669 K1 ; select CoreXY mode
          M551 P"mithunji" ; set password
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; physical drive 0 goes forwards
          M92 X80.00 Y80.00 Z2560.00 E100.00 ; set steps per mm
          M566 X600.00 Y600.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X2000.00 Y2000.00 Z50.00 E3000.00 ; set accelerations (mm/s^2)
          M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X230 Y270 Z200 S0 ; set axis maxima
          M558 P5 C"^zprobe.in" H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20 ; define mesh grid
            nirmal2013
            Both the motors are connected in Z pins, & motors are NEMA17, 4.2kg/cm with 1.2Amps
            • Vetiundefined
              Veti
              the motors on z are wired in series. this haves the voltage.
              6v will not be enough to drive the motors.
              connect the second z motor to e1.
              change M584 X0 Y1 Z2 E3 to M584 X0 Y1 Z2:4 E3
              place the jumpers back on the second z connector.
              your thermistor settings are incorrect. find the correct beta value in your thermistor documentation.
              you have not pid tuned the bed or heater.
              you are missing the offset of the probe
              nirmal2013undefined 2 Replies Last reply Reply Quote 1
                nirmal2013 @Veti
                @Veti, thanks a lot for immediate reply...
                Z motors are sorted now....
                will check the thermistor settings...
                  nirmal2013 @Veti
                  @Veti said in Help me with dual z motors:
                  yes, yet to do... thanks!
