    SD CARD 1 doesn't panelue sd card
    Duet Web Control
    371
    • Stephen6309undefined
      Stephen6309
      SD CARD 1 in DWC doesn't show the panldue sd card in the 4.3 display. It appears to show the boot drive of the PI4. The card placed in the paneldue 4.3 inch is blank.
      Duet Web Control 3.2.0-rc2
      FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
        I think that's to be expected: https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_PanelDue_3_connection_matrix
        Stephen6309undefined 1 Reply Last reply Reply Quote 0
          Stephen6309 @Phaedrux
          @Phaedrux Doesn't say thing about that, or mention a Duet 3 Mini+
            You're right. Checking.
            • Vetiundefined
              Veti
              sd card support is on the todo list.
              its not implemented at the moment as far as i know for the duet 3 series.
                As I suspected, the mini5 is in the same boat as the Duet 3 6HC.
                Here's what David had to say: "Yes, that's expected. If RPi can support SPI-connected SD cards then it would be possible to makeup a special cable to connect the SD card pins of PanelDue to the Pi, however work on DSF would still be needed to make it available."
                So it's something on the list to look into but nothing at the moment.
                • chrishammundefined
                  chrishamm administrators
                  Actually it's a configuration issue on the RaspPi. DSF scans for available mount points every few seconds and when it detects new items they're shown as "SD cards" in DWC. That's the same reason the first boot partition of Raspbian shows up as "SD Card 1".
                  With some extra work it would be probably easier to set up usbmount or another auto-mount utility on the Pi and to use a USB drive instead of an SD card (although I suppose something similar could be achieved with a USB <-> SD adapter). The only things that needs to be taken care of are permissions. Starting from software version 3.2 the dsf user and/or group will require read access to mount points to use them. It might suffice to add the dsf user to the disk or users group too (sudo gpasswd -a dsf disk). However a restart might be still required.
                  I bet it is possible to hook up the PanelDue SD card connector to the RaspPi expansion header but that's nothing I would recommend because it may interfere with the communication to the Duet which could lead to potential instability.
                  Duet software engineer
                    @Phaedrux On a Duet 2 that was on the machine, I could read the card, but not write. Using the 10pin cable, that's stated to allow the paneldue sd card access.
                    • A Former User?
                      A Former User
                      could perhaps use the second spi bus to avoid interfering with the one used for the duet, think all 40 pin pi's have two spi busses, then fuse to overlay or something while waiting for proper support
                        @Stephen6309, as you are using a Pi, why not mount somethink like this https://www.ebay.co.uk/itm/15cm-USB-2-0-Panel-Mount-A-Female-Socket-to-A-Type-Male-Plug-Cable-008742/192949267567 next to the PanelDue?
                          Stephen6309 @dc42
                          @dc42 I've seen that, but I thought the one on the 4.3 screen would work. Haven't had a real need to use a seperate sd card.
