    Can't preheat tool before homing
    Firmware installation
    222
    • calvinibaundefined
      calviniba
      I just updated the firmware from 2.x to 3.2 on my e3d beta toolchanger and had to redo the config in the process. I tried to start a print but it shows an insufficient axis homed error.
      My start G code goes something like this:
      select tool
      preheat tool and bed
      T-1 (deselect tool)
      home all axis and mesh bed level
      select tool (actually go and get it)
      start print
      previously it didnt care that it wasn't homed when i selected a tool. how do i make it like that again?
        We'd need to see your gcode files.
        Or you can compare against these RRF3 tool changer files.
        https://github.com/Duet3D/RRF-machine-config-files/tree/master/E3D_Tool_Changer/dc42-duet3-centreZero-2Titan-2Hemera
        calvinibaundefined 2 Replies Last reply Reply Quote 0
          calviniba @Phaedrux
          This post is deleted!
            calviniba @Phaedrux
            @Phaedrux https://github.com/calviniba/e3d-toolchanger Here are my gcode files for my toolchanger. I'm using a duet 2 wifi board
              Did you look at the RRF3 examples? Yes its for a Duet 3 but the tool change files would still be relevant. Only pin names would really be different.
              calvinibaundefined 1 Reply Last reply Reply Quote 0
                calviniba @Phaedrux
                @Phaedrux The only thing that I notice is that my toolchanges are done in tpostX.g instead of split between tpreX.g and tpostX.g, but that shouldn't change anything. Am I correct?
                  calviniba
                  Here is my start gcode in cura:
                  T-1
                  M84 ; motors off
                  M106 P2 S0
                  M106 P4 S0
                  M106 P6 S0
                  M106 P8 S0
                  G28 ;Home
                  G29 ;mesh bed leveling
                  G92 E0
                  M83 ; relative extrusion
                  G92 E0
                  which turns into:
                  T0
                  M190 S110
                  M104 S255
                  M109 S255
                  M82 ;absolute extrusion mode
                  T-1
                  M84 ; motors off
                  M106 P2 S0
                  M106 P4 S0
                  M106 P6 S0
                  M106 P8 S0
                  G28 ;Home
                  G92 E0
                  G92 E0
                  T0
                    When you select the tool at the start, use the P0 parameter in the T0 command, to tell RRF not to run the tool change files. Similarly on the T-1 command.
