Unsolved G30 S-2 does not work in RRF3.2
Hi, as the title says after updating the G30 S-2 command to RRF3.2 it seems to me that it does not update the position.
List what I tried to do:
-I made first print and had to raise the Z by 0.4 with babystepping
-I have corrected G31 Z value in config.g
-I started printing again but had to correct Z of 0.4 again with babystepping.I believe that the G30 S-2 command at start of printing does not correct Z offset value.
I also point out some warnings that appear when config.g is loaded:
6/1/2021, 12:00:43 Warning: M307: Heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C 6/1/2021, 12:00:43 Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 686C 6/1/2021, 12:00:43 Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 198C
@dc42, I haven't tried to change the tool with this version yet, has the problem I exposed yesterday (https://forum.duet3d.com/topic/20721/tool-change-problem-think), been solved?
If you can help attach the reportm122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKF0-3S86T-9A5YD Used output buffers: 1 of 40 (28 max) === RTOS === Static ram: 149788 Dynamic ram: 64176 of which 120 recycled Never used RAM 144748, free system stack 182 words Tasks: Linux(ready,77) HEAT(blocked,296) CanReceiv(blocked,813) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,50) MAIN(running,1145) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:16:55 ago, cause: software Last software reset at 2021-01-06 12:00, reason: User, FilamentSensors spinning, available RAM 144056, slot 1 Software reset code 0x000d HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 23.9, current 24.0, max 24.6 Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Driver 0: position 0, standstill, reads 32180, writes 19 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 32180, writes 19 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 32183, writes 17 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 32182, writes 18 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 32183, writes 17 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 32183, writes 17 timeouts 0, SG min/max 0/0 Date/time: 2021-01-06 12:17:33 Slowest loop: 1.72ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 4071, send timeouts 0, received 12178, lost 0, longest wait 1ms for reply type 6042, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 37808/37808 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8a8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 37.28 Maximum length of RX/TX data transfers: 5456/980
