Unsolved Duet3 resets mid print on RRF 3.2
My setup:
RPi4, Duet3 6CH and 3CH Expansion board latest stable RRF 3.2 installed yesterday.Already had 2 instances of board reset mid-print, print status reported as completed. Diagnostic reporting
Last reset 00:48:00 ago, cause: watchdog
Also getting constant disconnects
Warning: Lost connection to Duet (Board is not available (no header))
Duet3 diagnostics
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 149788 Dynamic ram: 63136 of which 68 recycled Never used RAM 145840, free system stack 124 words Tasks: Linux(ready,95) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,344) CanClock(blocked,352) TMC(blocked,19) MAIN(running,717) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:48:00 ago, cause: watchdog Last software reset at 2021-01-06 15:10, reason: User, none spinning, available RAM 145840, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 35.0, current 37.4, max 37.6 Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0 Driver 0: position 81124, standstill, reads 27916, writes 22 timeouts 0, SG min/max 0/247 Driver 1: position 3042, standstill, reads 27917, writes 22 timeouts 0, SG min/max 0/244 Driver 2: position 705, standstill, reads 27917, writes 22 timeouts 0, SG min/max 0/255 Driver 3: position 0, standstill, reads 27917, writes 22 timeouts 0, SG min/max 0/266 Driver 4: position 0, ok, reads 27917, writes 22 timeouts 0, SG min/max 0/1023 Driver 5: position 0, ok, reads 27917, writes 22 timeouts 0, SG min/max 0/851 Date/time: 2021-01-06 15:58:16 Slowest loop: 181.89ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 887437ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 30838, completed moves 30809, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.3 === GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X249.156006 Y219.667999 E0.013370" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 37418, send timeouts 0, received 7, lost 0, longest wait 1ms for reply type 6042, free buffers 48 === SBC interface === State: 0, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 50811/50812 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c8a8 Buffer RX/TX: 48/1560-0 === Duet Control Server === Duet Control Server v3.2.0 File: Buffered code: G1 X249.156 Y219.668 E0.01337 Buffered code: G1 X249.383 Y219.895 E0.01068 Buffered code: G1 X249.472 Y220.287 E0.01337 Buffered code: G1 X249.472 Y222.095 E0.06013 Buffered code: G1 X249.492 Y222.913 E0.02721 Buffered code: G1 X249.557 Y223.75 E0.02792 Buffered code: G1 X249.664 Y224.582 E0.0279 Buffered code: G1 X249.813 Y225.406 E0.02785 Buffered code: G1 X250.005 Y226.223 E0.02791 Buffered code: G1 X250.238 Y227.029 E0.02791 Buffered code: G1 X250.511 Y227.819 E0.0278 Buffered code: G1 X250.745 Y228.402 E0.02089 Buffered code: G1 X250.829 Y228.604 E0.00728 Buffered code: G1 X251.179 Y229.359 E0.02768 Buffered code: G1 X251.57 Y230.099 E0.02784 Buffered code: G1 X251.998 Y230.819 E0.02786 Buffered code: G1 X252.463 Y231.515 E0.02784 Buffered code: G1 X252.967 Y232.194 E0.02813 Buffered code: G1 X253.498 Y232.837 E0.02774 Buffered code: G1 X254.064 Y233.455 E0.02787 Buffered code: G1 X254.661 Y234.042 E0.02785 Buffered code: G1 X255.288 Y234.6 E0.02792 Buffered code: G1 X255.942 Y235.124 E0.02787 Buffered code: G1 X256.621 Y235.613 E0.02783 Buffered code: G1 X257.328 Y236.07 E0.028 Buffered code: G1 X258.053 Y236.487 E0.02782 Buffered code: G1 X258.798 Y236.866 E0.0278 Buffered code: G1 X259.372 Y237.125 E0.02094 Buffered code: G1 X259.572 Y237.211 E0.00724 Buffered code: G1 X260.285 Y237.489 E0.02545 Buffered code: G1 X260.822 Y237.671 E0.01886 Buffered code: G1 X261.025 Y237.737 E0.0071 ==> 1528 bytes Code buffer space: 2540 Configured SPI speed: 8000000 Hz Full transfers per second: 40.41 Maximum length of RX/TX data transfers: 3176/1684 File /opt/dsf/sd/gcodes/ZR_BearingTopMount_FR.gcode is selected, processing
3CH ecpansion diagnostics
M122 B1 Diagnostics for board 1: Duet EXP3HC firmware version 3.2 (2021-01-05) Bootloader ID: not available Never used RAM 154848, free system stack 154 words HEAT 90 CanAsync 94 CanRecv 83 TMC 30 MAIN 293 AIN 257 Last reset 22:54:23 ago, cause: power up Last software reset data not available Driver 0: position 0, 80.0 steps/mm, standstill, reads 40773, writes 0 timeouts 0, SG min/max not available Driver 1: position 4730738, 172.0 steps/mm, ok, reads 40750, writes 22 timeouts 0, SG min/max 0/723 Driver 2: position 0, 80.0 steps/mm, standstill, reads 40772, writes 0 timeouts 0, SG min/max not available Moves scheduled 619649, completed 619599, in progress 1, hiccups 1556 Next step interrupt due in 2509 ticks, enabled VIN: 24.6V, V12: 12.3V MCU temperature: min 43.8C, current 44.0C, max 44.2C Ticks since heat task active 5, ADC conversions started 82463996, completed 82463996, timed out 0 Last sensors broadcast 0x00000000 found 0 9 ticks ago, loop time 0 CAN messages queued 36, send timeouts 0, received 859805, lost 0, free buffers 32
Is this a recent setup of DuetPi or the version that came on the SD card with the board?
A quick test would be to setup a new SD card with a fresh DuetPi image and then doing an apt update.
https://pkg.duet3d.com/DuetPi-lite.zip
https://pkg.duet3d.com/DuetPi.zip
How is the Pi4 powered?
@Phaedrux said in Duet3 resets mid print on RRF 3.2:
SD card (Pre imaged) that came with Duet3 board
RPi 4 powered from it's own power supply (MEAN WELL 323282 RS-25-5 ) -
@evomotors said in Duet3 resets mid print on RRF 3.2:
Definitely try a fresh one.
