    3.2 JSON Parse error: Unrecognized token '<' Password bug
    Beta Firmware
    8
    58
    3.7k
    • Charlieundefined
      Charlie
      After updating to RRF 3.2, I am getting this error:
      Connection interrupted, attempting to reconnect...
      It appears to happen continuously.
      Does anyone know what may have caused this?
      Im not completely sure exactly what files were required to be installed, so I may be missing some system files. I have these:
      Are there any that I should add or remove?
      Thank you for your time! 🙂
        I suggest you try updating again by uploading this zip file as is without extracting it to the system tab.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        Charlieundefined 1 Reply Last reply Reply Quote 0
        • chrishammundefined
          chrishamm administrators
          If it happens right after connecting try to delete the dwc*.json files from /sys.
          Duet software engineer
          Charlieundefined 2 Replies Last reply Reply Quote 0
          • Charlieundefined
            Charlie @chrishamm
            @chrishamm
            I assume you mean the "dwc-settings.json" and the "dwc2settings.json", correct?
            What exactly do they do? Do I need to worry about settings being reset?
            • Charlieundefined
              Charlie @Phaedrux
              @Phaedrux
              Unfortunately this did not work. I still get the same "JSON Parse error: Unrecognized token '<' "
                Is that after a fresh upload of the zip file?
                Clear your browser cache?
                • Charlieundefined
                  Charlie @Phaedrux
                  @Phaedrux
                  Correct, that is after a fresh upload of the zip file. This is how I uploaded it: DWC > Files > System > Selected "Upload System Files" on the right side of the screen. > Uploaded .zip file.
                  Clearing the browser cache unfortunately did not fix the issue.
                  Seems to happen around 45 seconds after connection is established.
                    Does it still happen if you delete the 3 .JSON files? (after downloading a backup of course)
                    Can you upload those .json files here?
                    • Charlieundefined
                      Charlie @Phaedrux
                      @Phaedrux
                      Ive been deleting the files via the DWC. Is that sufficient, or should I do it through "sys" on the SD card?
                      Will there be any sensitive information on the .JSON files that I need to scrub?
                        Deleting them in DWC should be sufficient.
                        You can open the JSON files in a text editor to see what's in them first if you wish. I don't think there's anything sensitive in there though.
                        Also post your config.g and the results of M122 if possible so we can see which board it is and what firmware is actually installed.
                        • Charlieundefined
                          Charlie @Phaedrux
                          @Phaedrux
                          Cool, yes, deleting them in DWC does appear to delete them in the "sys" folder.
                          Unfortunately it appears that .JSON files cannot be uploaded to the forum. I can copy and paste the info from a text editor if you'd like, but deleting them did not appear to fix the issue.
                          Here is the config.g file:
                          ; Creality.
                          ; 0:/sys/config.g
                          ; Configuration file for Duet WiFi (firmware version 3.1.1).
                          ; Executed by the firmware on start-up.
                          ; 2020/01/05/20:24.
                          ; General Preferences.
                          G90               ; Set all axes (not extruders) to absolute positioning.
                          M83               ; Set all extruders (not axes) to relative positioning.
                          M550 P"Creality"  ; Set machine name.
                                            ; P (Machine name): Creality.
                          M669 K0           ; Set kinematics type and parameters.
                                            ; K (Kinematics type): 0 (Cartesian).
                          ; Network.
                          M551 P"REDACTED"  ; Set machine password.
                                               ; P (Password): ...
                          M552 S1              ; Set network.
                                               ; S (Networking): 1 (Enable networking as a client).
                          M586 P0 S1           ; Set network protocols.
                                               ; P (Protocol type): 0 (HTTP or HTTPS).
                                               ; S (Protocol command): 1 (Enable).
                          M586 P1 S0           ; Set network protocols.
                                               ; P (Protocol type): 1 (FTP or SFTP).
                                               ; S (Protocol command): 0 (Disable).
                          M586 P2 S0           ; Set network protocols.
                                               ; P (Protocol type): 1 (Telnet or SSH).
                          ; Drives.
                          M569 P0 S1                                 ; Set motor driver direction.
        ; P (Motor drive number): 0 (X motor board label, X motor).
        ; S (Direction of movement): 1 (Forward).
                          M569 P1 S1                                 ; Set motor driver direction.
        ; P (Motor drive number): 1 (Y motor board label, Y motor).
                          M569 P2 S1                                 ; Set motor driver direction.
        ; P (Motor drive number): 2 (Z1 motor board label, Left Z [Z1] motor).
                          M569 P3 S1                                 ; Set motor driver direction.
        ; P (Motor drive number): 3 (E0 motor board label, E0 motor).
                          M569 P4 S1                                 ; Set motor driver direction.
        ; P (Motor drive number): 4 (E1 motor label, Right Z [Z2] motor).
                          M584 X0 Y1 Z2:4 E3                         ; Set drive mapping.
        ; X (Driver number for X motor): 0 (X motor label).
        ; Y (Driver number for Y motor): 1 (Y motor label).
        ; Z (Driver number for Z motor): 2 & 4 (Z1 motor label & E1 motor label).
        ; E (Driver number for E motor): 3 (E0 motor label).
                          M671 X-25:535 Y250:250 S20 F1.0            ; Set positions of z screws.
        ; X (X coordinates of Z screws): ...(-25mm X, 0mm Y offset on left. 25mm X, 0mm Y offset on right.) 0 (-22, 535), 1 (520, 250).
        ; Y (Y coordinates of Z screws): ...
        ; S (Maximum correction to apply to each Z screw [mm]): 20.
        ; F (Fudge factor): 1.0.
                          M350 X16 Y16 Z16 E16 I1                    ; Set microstepping and interpolation.
        ; X (Stepping mode for the X axis): 16 (1/16 step).
        ; Y (Stepping mode for the Y axis): 16 (1/16 step).
        ; Z (Stepping mode for the Z axis): 16 (1/16 step).
        ; E (Stepping mode for the extruder): 16 (1/16 step).
        ; I (Microstepping interpolation mode): 16(Enable).
                          M92 X80.00 Y80.00 Z400.00 E824.00          ; Set axis steps per unit.
        ; X (Steps/mm for X axis): 80.00.
        ; Y (Steps/mm for Y axis): 80.00.
        ; Z (Steps/mm for Z axis): 400.00.
        ; E (Steps/mm for extruder): 824.00.
                          M566 X480.00 Y480.00 Z12.00 E10000.00      ; Set maximum instantaneous speed change (jerk).
        ; X (Maximum instantaneous speed change for X axis [mm/min]): 480.00.
        ; Y (Maximum instantaneous speed change for Y axis [mm/min]): 480.00.
        ; Z (Maximum instantaneous speed change for Z axis [mm/min]): 12.00.
        ; E (Maximum instantaneous speed change for extruder [mm/min]): 10,000.00.
                          M203 X21000.00 Y21000.00 Z900.00 E1500.00  ; Set maximum speeds.
        ; X (Maximum speed for X axis [mm/min]): 21,000.00.
        ; Y (Maximum speed for Y axis [mm/min]): 21,000.00.
        ; Z (Maximum speed for Z axis [mm/min]): 900.00.
        ; E (Maximum speed for extruder [mm/min]): 1,500.00.
                          M201 X500.00 Y500.00 Z20.00 E10000.00      ; Set maximum print move accelerations.
        ; X (Maximum acceleration for X axis [mm/s^2]): 500.00.
        ; Y (Maximum acceleration for Y axis [mm/s^2]): 500.00.
        ; Z (Maximum acceleration for Z axis [mm/s^2]): 20.00.
        ; E (Maximum acceleration for extruder [mm/s^2]): 10,000.00.
                          M906 X1500 Y1500 Z1100 E1400 I30           ; Set maximum motor currents.
        ; X (X drive maximum motor current [mA]): 1500.
        ; Y (Y drive maximum motor current [mA]): 1500.
        ; Z (Z drive maximum motor current [mA]): 1100.
        ; E (Extruder maximum motor current [mA]): 1400.
        ; I (Motor current idle factor): 30.
                          M84 S30                                    ; Set idle timeout in seconds of inactivity.
        ; Stop idle hold.
        ; S (Idle time out[seconds]): 30.
                          ; Axis Limits.
                          M208 X0 Y0 Z0 S1        ; Set axis minimum.
                          M208 X475 Y500 Z500 S0  ; Set axis maximum.
                          ; Endstops.
                          M574 X1 P"xstop" S1  ; Set endstop configuration.
                                               ; X (Position of X endstop): 1 (Low end).
                                               ; P (Pin name): xstop.
                                               ; S (Endstop type): 1 (Switch type).
                          M574 Y1 P"ystop" S1  ; Set endstop configuration.
                                               ; Y (Position fo Y endstop): 1 (Low end).
                                               ; P (Pin name): ystop.
                          M574 Z0              ; Set endstop configuration.
                                               ; Z (Position fo Z endstop): 0 (None).
                          ; Z-Probe.
                          M558 K0 P8 F60 H2 R0 T6000 A1 B1 C"!^zprobe.in"  ; Set Z probe type.
                          M950 S0 C"!^zprobe.in"                           ; Create GPIO/servo pin.
                          G31 P500 X53.100 Y9.000 Z0.400 K0                ; Set Z probe.
                          M557 X56:475 Y25:475 P4                          ; Define Z probe mesh grid (This is probe grid, not nozzle grid).
                          ; Heater, Bed.
                          M308 S0 P"bedtemp" Y"thermistor" A"Bed Temp" T100000 B3950 R4700  ; Set sensor parameters.
                          M950 H0 C"bedheat" Q10 T0                                         ; Create heater.
                          M307 H0 V0 B0 S1.0                                                ; Set heating process parameters.
                          M140 H0                                                           ; Set bed heater.
                          M143 H0 S120                                                      ; Set maximum heater temperature (deg C).
                          ; Heater, Extruder 1.
                          M308 S1 P"e0temp" Y"thermistor" A"Extr. 1 Temp" T100000 B4725 C7.06e-8  ; Set (Extruder 1) temperature sensor parameters.
        ; S (Sensor number): 1.
        ; P (Pin name): e0temp.
        ; Y (sensor type): thermistor.
        ; A (Sensor name): Extr 1. Temp.
        ; T (Thermistor resistance at 25 deg C): 100,000.
        ; B (Beta value): 4725.
        ; C (Coefficient): 7.06e-8.
                          M950 H1 C"e0heat" T1                                                    ; Create heater (extruder 1).
        ; H (Heater number): 1.
        ; C (Pin name): e0heat.
        ; T (Temperature sensor number): 1.
                          M307 H1 R1.481 C620.7:352.3 D6.65 I0 B0 S1.00 V24.1                     ; Set heating process parameters.
        ; R (Heating rate): 1.481.
        ; C (Dominant time constant of heating process [seconds]): 620.7 (print fans off) : 352.3 (print fans fully on).
        ; D (Dead time [seconds]): 6.65.
        ; I (Invert PWM signal): 0 (Not inverted).
        ; B (Bang bang control): 0 (Disabled).
        ; S (Maximum PWM frequency to use): 1.00.
        ; V (Vin calibration supply voltage): 24.1.
                          M143 H1 S285                                                            ; Set maximum heater temperature (deg C).
                          ; Fans, Print Cooling.
                          M950 F0 C"fan0" Q100                        ; Create fan.
        ; F (Fan number): 0.
        ; C (Pin name): fan0.
        ; Q (PWM frequency [Hz]): 100.
                          M106 P0 L0.2 X1.0 B0.3 H-1 R1 C"Print Fan"  ; Set fan.
        ; P (Fan number): 0.
        ; L (Minimum fan speed): 0.2.
        ; X (Maximum fan speed): 1.0.
        ; B (Blip time [seconds]): 0.3.
        ; H (Thermostatic control): -1 (Disabled).
        ; R (Restore fan speed): 1 (To the value it has when the print was paused).
        ; C (Name): Print Fan.
                          ; Fan, Heat Break.
                          M950 F1 C"fan1" Q100                                  ; Create fan.
        ; F (Fan number): 1.
        ; C (Pin name): fan1.
                          M106 P1 S1.0 L0.5 X1.0 B0.3 H1 T45 C"Heat Break Fan"  ; Set fan.
        ; P (Fan number): 1.
        ; S (Fan speed): 1.0.
        ; H (Enable thermostatic control): 1 (Extruder temp sensor).
        ; T (Thermostatic trigger temperature [C]): 45.
        ; C (Name): Heat Break Fan.
                          ; Fans, Case.
                          M308 S2 Y"drivers" A"Driver Temp"                    ; Set (stepper drivers) temperature sensor.
        ; S (Sensor number): 2.
        ; Y (Sensor type): drivers (Main board stepper drivers).
        ; A (Sensor name): Driver Temp.
                          M308 S3 Y"mcu_temp" A"CPU Temp"                      ; Set (CPU/MCU) temperature sensor.
        ; S (Sensor number): 3.
        ; Y (Sensor type): mcu_temp (CPU/MCU).
        ; A (Sensor name): CPU Temp.
                          M950 F2 C"fan2" Q25000                               ; Create fan.
        ; F (Fan number): 2 (Case fan).
        ; C (Pin name): fan2.
        ; Q (PWM frequency [Hz]): 25,000.
                          M106 P2 L0.8 X1.0 B0.1 H2:3 T40:65 C"Case Fan"       ; Set fan.
        ; P (Fan number): 2 (Electronics).
        ; L (Minimum fan speed): 0.8.
        ; B (Blip time [seconds]): 0.1.
        ; H (Thermostatic control): 2 (stepper drivers) : 3 (CPU/MCU).
        ; T (Thermostatic trigger temperature [C]: 40-65 (Proportional range).
        ; C (Name); Case Fan.
                          ; Tools.
                          M563 P0 S"Extr. 1 Tool" D0 H1 F0                       ; Define tool.
        ; P (Tool number): 0 (Extruder 1).
        ; S (Tool name): Extr. 1 Tool.
        ; D (Extruder drive): 0.
        ; H (Heater): 1 (Extruder 1).
        ; F (Fan mapped): 0 (Print cooling fan).
                          G10 P0 X0 Y0 Z0 R0 S0                                  ; Set tool offset and temperature.
        ; P (Tool number): 0.
        ; X (X offset): 0.
        ; Y (Y offset): 0.
        ; Z (Z offset): 0.
        ; R (Standby temperature): 0.
        ; S (Active temperature: 0.
                          M591 D0 P3 C"e0stop" S1 R75:125 E3.0 A1 L25.44         ; Configure filament sensing.
        ; D (Extruder drive number): 0.
        ; P (Type of sensor): 3 (Duet3D rotating magnet sensor).
        ; C (Pin name): e0stop.
        ; S (Filament monitoring): 1 (Enabled).
        ; R (Filament movement tolerance [%]): 75:125.
        ; E (Extrusion length [mm]): 3.0.
        ; A (Check extruder motion): 1 (Check all extruder motion).
        ; L (Filament length per rotation of the sense wheel [mm]): 25.44.
                          ; Display.
                          M575 P1 B57600 S1     ; Set serial communications parameters.
                                                ; P (Serial channel number): 1 (Auxiliary serial port).
                                                ; B (Baud rate): 57,600.
                                                ; S (Mode): 1 (PanelDue, checksum required).
                          ; Automatic Power Saving.
                          M911 S23.5 R24.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-2 F2400"  ; Set auto save on power loss.
        ; S (Auto save threshold [V]): 23.5.
        ; R (Resume threshold [V]): 24.0.
        ; P (Commands on power loss): ...
                          ; CPU Temperature Compensation.
                          M912 P0 S-4.7  ; Set electronics temperature monitor adjustment.
                                         ; P (Temperature monitor channel): 0 (Default).
                                         ; S (Value to be added to temperature reading [C]): -4.7 (Lower number decreases displayed cpu temp.)
                          ; Pressure Advance.
                          M572 D0 S0.06  ; Set extruder pressure advance.
                                         ; D (Extruder number): 0.
                                         ; S (Pressure advance amount [seconds]): 0.06.
                          M501  ; Load saved parameters from non-volatile memory.
                          ; Select tool.
                          T0  ; Select first tool.
                          • Charlieundefined
                            Charlie
                            M122:
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                            Board ID: 08DGM-917DA-G4MS8-6J1DD-3S46R-1STHB
                            Used output buffers: 3 of 24 (11 max)
                            Static ram: 23460
                            Dynamic ram: 74108 of which 40 recycled
                            Never used RAM 14472, free system stack 180 words
                            Tasks: NETWORK(ready,162) HEAT(blocked,295) MAIN(running,448) IDLE(ready,19)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:06:49 ago, cause: power up
                            Last software reset at 2021-01-06 23:23, reason: User, GCodes spinning, available RAM 14472, slot 1
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            MCU temperature: min 16.0, current 19.8, max 20.7
                            Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: position 0, standstill, SG min/max not available
                            Driver 1: position 0, standstill, SG min/max not available
                            Driver 2: position 0, standstill, SG min/max not available
                            Driver 5: position 0
                            Driver 6: position 0
                            Driver 7: position 0
                            Driver 8: position 0
                            Driver 9: position 0
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2021-01-07 13:19:54
                            Cache data hit count 498401202
                            Slowest loop: 8.01ms; fastest: 0.21ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 5.6ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 16.82ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            - WiFi -
                            Network state is active
                            WiFi firmware version 1.25
                            WiFi MAC address ec:fa:bc:2d:dd:0f
                            WiFi Vcc 3.39, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 27136
                            WiFi IP address 192.168.1.44
                            WiFi signal strength -71dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            === Filament sensors ===
                            Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                              In the General tab of DWC do you have Save settings in local storage and Save cache in local storage checked or unchecked? Either way can you try toggling that?
                              Also, your wifi signal strength is pretty borderline.
                              Is the printer far from the router?
                              • Charlieundefined
                                Charlie @Phaedrux
                                @Phaedrux
                                Save settings in local storage: Unchecked.
                                Save cache in local storage: Checked.
                                Ill try toggling both and see if there is any change.
                                Yeah, its pretty far from the router, though Ive never had any issues before using 1.21, 2.0.3, or 3.1.1 (even when it was in a steel case, lol).
                                  Phaedrux Moderator @Charlie
                                  @Charlie Also try with both off and both on.
                                  I'm just poking in the dark here. I'm not certain it's related.
                                  • Charlieundefined
                                    Charlie @Phaedrux
                                    @Phaedrux
                                    Definitely will do. Your guesses are way more educated than mine, so I greatly appreciate it. Ill let you know the results.
                                      My theory is that it's trying to save the cache or settings on the SD card and the weak wifi signal is causing issues.
                                      I'm not sure which storage the "local storage" is referring to. It's a bit ambiguous and I never got clarification last time it came up. It's either the SD card as in local to the machine, or the browser side, as in local to the viewer.
                                      @chrishamm will know for sure, but he's probably sleeping like a baby at the moment. 😉
                                      • Charlieundefined
                                        Charlie @Phaedrux
                                        @Phaedrux
                                        Unfortunately all four configurations (emptying browser cache each time) still had the same error come up.
                                          My last suggestion is to manually replace the contents of the /www folder with a fresh set from https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
                                          And if that doesn't work, try a fresh SD card.
                                          And if that doesn't work, wait for chrishamm
                                          • Charlieundefined
                                            Charlie @Phaedrux
                                            @Phaedrux
                                            Unfortunately manually replacing the www folder did not change anything, and neither did a new SD card. Thank you for your input though!
