    Syntax Highlighter for RepRap Gcode
    Gcode meta commands
    1
    1
    421
    • garethky
      garethky last edited by
      I've started work on an syntax highlighter grammar for RepRap GCode. These are the results (of some absolute garbage code) in Sublime Text 3:
      So far it knows about G, M & T commands, expressions, language keywords, comments etc. Open source of course: https://github.com/garethky/RepRapGCodeSyntaxHighlighter/tree/development
      (I'm pointing you to the development branch because its not ready for a mainline release yet)
      I didn't want to do this for just my editor, so I found a tool called Iro. Iro uses a generic grammar and then generates the highlighter files for a slew of popular text editors. Its not perfect, its not open source and I have already found some bugs, but it got me 95% the way there for 1 editor so far (and apparently Sublime is the editor with the weakest support). If you are an editor guru and want to help out I would like your support:
      • You can generate the grammar for your editor using the .rion file on github and test your editor and tell me if it works or not
      • You can contribute the Scope mappings for Pygments & Rogue
      • You want to fix something or make something better, please submit a patch on github
      1 Reply Last reply Reply Quote 6
      • Unpinned by  T3P3Tony T3P3Tony
