    Anything special to do after changing to 9° steppers?
    • number40fan
      number40fan last edited by
      Besides changing the steps/mm? Anything that can be adjusted to take advantage of the extra steps or just run it?
        To get high speeds using 0.9deg motors, you may need to use 24V power if you don't already.
        • number40fan
          What do you consider to be high speeds?
            You can work out what supply voltage you need to maintain torque up to your chosen target speed. See https://duet3d.com/wiki/Choosing_stepper_motors#How_to_work_out_the_power_supply_voltage_you_need.
            • number40fan
              I see you had issues at 150mm/s. I am good at 90, so I think I'll stick with 12 volts. Appreciate the link.
