    help to fix z-axis double scale / config geometry
    Firmware installation
    • c310undefined
      c310
      Please help to find configuration bug in new delta:
      motors 0.9 deg 17HM19-2004
      16 teeth pulley with GT2 belt
      RRF/DWC 3.2
      what happens: when homing printer, it works fine and effector coordinates show correctly in DWC
      when i move effector Z 5 mm down by DWC , it physically moves 10mm. 😞
      what should be changed in my configuration to achieve proper axis scale?
      thanks!
      this is portion of relates config.g
      M92 X400 Y400 Z400  		; Set axis steps/mm http://prusaprinters.org/calculator/#stepspermmbelt
      M350 X32 Y32 Z32 I1      		; Set 32x microstepping with interpolation
      M665 L288.17 R159 H215 B130 		; set diagonal rod length, delta radius, homed height and printable radius
      config-override is not loaded (commented out M501)
      H is distance between bed and nozzle when effector is centered at maximum height.
      • Vetiundefined
        Veti
        @c310 said in help to fix z-axis double scale / config geometry:
        move this line above M92. also you are missing the E setup.
        also if you have a duet wifi the interpolation will not work. only at x16
        • c310undefined
          c310
          @Veti said in help to fix z-axis double scale / config geometry:
          M350 E config is configured separately and is sitting in other section below
          ....thank you for the hint. i tried different combinations with 16 and 32 microsteps, interpolation On and Off.
          the only one that keeps proper scale is 32 mirosteps without interpolation
          16 microsteps with or without interpolation with 400 steps per mm of 0.9 deg motor leads to double scale of axis...
          just in case - this is full config of duetwifi config.g
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @c310
            16x with 0.9 is 200 steps/mm
            c310undefined 1 Reply Last reply Reply Quote 0
              jay_s_uk
              @c310
              as @Veti states, the order is important.
              At the moment, because the default is x16, you are setting the steps per mm to 400.
              Then, when you set the drivers to x32, the steps per mm are automatically doubled to 800.
              Move the M92 as veti instructed
              • c310undefined
                c310 @Veti
                @Veti thanks!!!!
