Error: Heater 0 fault: heater monitor 0 was triggered
@dmbgo said in Error: Heater 0 fault: heater monitor 0 was triggered:
M303 H0 P0.4 S120
Why did you reduce the PWM factor so much?
Hmmm, I seem to have this error when doing the Autotune:
1/14/2021, 12:34:32 PM Auto tune cancelled because target temperature was not reached
1/14/2021, 12:04:32 PM Auto tune starting phase 1, heater on
1/14/2021, 12:04:26 PMAutotune didn't work, the second attempt at autotune led to the error above, however printing with the heatbed PID settings from an earlier firmware version that did successfully autotune, I have not experienced anymore heatbed errors.
Given that the errors were very constant, I think that it might be fixed.
Thanks! -
Oh and the reduction of the PWM factor was from the example at:
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control -
Yes the previous tuned values should still be valid.
I would try tuning again with full power to see if it has better luck hitting the commanded temp.
It's just an example of how the power factor can be used. Normally you'd want to tune at full power. I'm going to change that example. Actually I don't see that example at all in that tuning link, but I did find it in the M303 entry in the gcode wiki and have changed it to use 100%. The only times you'd want to use that is with an overpowered heater that is throwing "heating too fast" errors.
That makes sense Phaedrux. I was wondering why it was 40%. Given that the errors seem to have gone after the FW update, and the bed is stable, do you see any reason not to move on?
Nope, I think you're good to go.
Thanks for your help.
