help for beginners
help to build the firmware for the duet 2 internet board with the BL Touch auto-level sensor and the end of the filament
start from here https://configtool.reprapfirmware.org/Start
here is a good guide https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
Hello. I have already dealt with the electrical part. I can't figure out how to configure the firmware and add a filament end sensor and 3D Touch auto level to it.
have you read part 5 of the guide?
Yes, I read it. today I got it like this.
- When printing with one m extruder, the model is printed everything seems to be good.
- When printing with two colors, a problem occurs, immediately from the very beginning of printing, the filament is fed very quickly and the movement of the X and Y axes instantly drops to almost zero. What can be wrong ?
Can you post your config.g?
Can you post your homeall.g?
Can you post the entire gcode file or at least the first 50 or so lines of it?
Can you send M122 and post the results?
Can you send M98 P"config.g" and post the results?
A description of your printer? What hardware? Photos?
Yes of course. minute
tpre1.g tpre0.g tpost1.g tpost0.g tfree1.g tfree0.g stop.g sleep.g resume.g pause.g homez.g homey.g homex.g homeall.g config.json config.g bed.g
М122
= = = Диагностика ===
RepRapFirmware для Duet 2 WiFi / Ethernet версии 2.05.1 работает на Duet Ethernet 1.02 или более поздней версии
ID платы: 08DLM-996RU-N8PS0-6J9FG-3S86R-9BSMN
Используемые выходные буферы: 1 из 24 (8 макс.)
= = = RTOS ===
Статическая оперативная память: 25712
Динамическая оперативная память: 93104, из которых 76 переработаны
Используемая оперативная память стека исключений: 320
Никогда не использованная оперативная память: 11860
Задачи: сеть (готова, 580) тепло (заблокировано, 1232) магистраль (работает, 3728) холостой ход(готов, 160)
Принадлежащие мьютексы:
= = = Платформа ===
Последний сброс 00: 00: 31 назад, причина: включение питания
Последний сброс программного обеспечения в 2021-01-20 15: 55, причина: пользователь, вращающийся модуль GCodes, доступная оперативная память 11660 байт (слот 2)
Код сброса программного обеспечения 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff задача 0x4449414d
Состояние ошибки: 0
Бесплатные записи файлов: 10
Обнаружена SD-карта 0, скорость интерфейса: 20,0 Мбайт / сек
SD-карта самое длинное время записи блока: 0.0 МС, Макс повторных попыток 0
Температура MCU: мин 32,6, ток 35,1, Макс 35,3
Напряжение питания: мин 12.0, ток 12.1, Макс 12.1, события под напряжением: 0, события над напряжением: 0, хорошая мощность: да
Драйвер 0: остановка, SG min / max недоступно
Драйвер 1: остановка, SG min / max недоступно
Драйвер 2: остановка, SG min / max недоступно
Драйвер 3: остановка, SG min / max недоступно
Драйвер 4: остановка, SG min / max недоступно
Дата / время: 2021-01-21 09: 37:59
Количество попаданий в кэш данных 57423877
Самый медленный цикл: 11,35 МС; самый быстрый: 0,07 МС
Ошибки I2C nak 0, тайм-ауты отправки 0, тайм-ауты приема 0, тайм-ауты завершения 0, сброс 0
= = = перемещение ===
Икота: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
Компенсация кровати в использовании: нет, comp offset 0.000
= = = DDARing ===
Запланированные ходы: 0, завершенные ходы: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
= = = тепло ===
Подогреватели кровати = 0 -1 -1 -1, камерные обогреватели = -1 -1
Нагреватель 1 включен, I-accum = 0.0
= = = GCodes ===
Сегменты слева: 0
Записи стека: 1 выделено, 0 используется
Блокировка движения, удерживаемая null
http простаивает в состоянии (ах) 0
telnet простаивает в состоянии (ах) 0
файл простаивает в состоянии (ах) 0
последовательный канал простаивает в состоянии (ах) 0
aux простаивает в состоянии (ах) 0
демон простаивает в состоянии(ах) 0
очередь простаивает в состоянии (ах) 0
автопауза простаивает в состоянии(ах) 0
Очередь кода пуста.
= = = Сеть ===
Самый медленный цикл: 11,91 МС; самый быстрый: 0,02 МС
Состояния ответчика: HTTP(0) HTTP(0) HTTP(0) HTTP (0) FTP(0) Телнет(0) Телнет(0)
HTTP-сессии: 1 из 8
Состояние интерфейса 5, Ссылка 100 Мбит / с полный дуплекс
translate.google
@sergei
please post the untranslated version
an untranslated version of the M 122 command?
@sergei
yes
М122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later
Board ID: 08DLM-996RU-N8PS0-6J9FG-3S86R-9BSMN
Used output buffers: 1 of 24 (8 max)
Static ram: 25712
Dynamic ram: 93104 of which 76 recycled
Exception stack ram used: 320
Never used ram: 11860
Tasks: NETWORK(ready,792) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
Owned mutexes:
Last reset 00:07:07 ago, cause: software
Last software reset at 2021-01-21 10:02, reason: User, spinning module GCodes, available RAM 11656 bytes (slot 3)
Error status: 0
Free file entries: 10
MCU temperature: min 36.6, current 36.9, max 37.4
Supply voltage: min 11.0, current 11.4, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2021-01-21 10:09:25
Cache data hit count 875887931
Slowest loop: 3.27ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 0 is on, I-accum = 0.0
Heater 2 is on, I-accum = 0.4
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 13.32ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duple
can you help with this problem?
post a sliced g code where the speed drops
it falls right after the start of printing
@sergei said in help for beginners:
did you set your slicer to reprap instead of marlin?
Yes of course
here is the complete code
