    Y movement homes to the wrong direction
    • sigourosandreasundefined
      sigourosandreas
      I have a custom toolchanger coreXY printer, mostly like the e3d toolchanger.
      The hardware endstops are Xmin, Ymax and a BLtouch for the bed at Zmin.
      I home the X correctly but the Y goes to Ymin instead of going to Ymax. I have checked the wiring, the movements of each motor (they move in the correct direction, X motor goes X+Y+ and Y motor goes X+Y-) and the firmware many times.
      Can anybody please help fix this strange thing?
      I use a duet wifi, firmware 3.2
      My config file is:
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Sun Jan 03 2021 18:41:40 GMT+0200 (Χειμερινή ώρα Ανατολικής Ευρώπης)
      M550 P"ToolChanger" ; set printer name
      M669 K1 ; select CoreXY mode
      ;M587 S"andreas" P"as2138774" ; WiFi Settings
      M552 S1 P"andreas" ; Enable WiFi Networking
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes forwards (X axis)
      M569 P1 S1 ; physical drive 1 goes forwards (Y axis)
      M569 P2 S1 ; physical drive 2 goes forwards (Z axis)
      M569 P3 S1 ; physical drive 3 goes forwards (E0)
      M569 P4 S2 ; physical drive 4 goes forwards (Coupler)
      M584 X0 Y1 Z2 E3 C4 ; set drive mapping
      M350 E16 C8 I0 ; configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E420.00 C100.00 ; set steps per mm
      M566 X400.00 Y400.00 Z10.00 E100.00 C2.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X16500.00 Y16500.00 Z1000.00 E5000.00 C5000 ; set maximum speeds (mm/min)
      M201 X4000.00 Y4000.00 Z400.00 E2500.00 C500.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1000 E1500 C400 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-7.5 Y0 Z0 C0 S1 ; set axis minima
      M208 X325 Y322 Z325 C500 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M574 C1 S3 ; configure sensorless endstop for low end on C
      ;Stall Detection
      M915 C S5 F0 H200 ; coupler
      G31 P500 X-15.3 Y49.47 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X2.5:325 Y49:315 S25 ; define mesh grid
      M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel 5 on the Duex board
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S140 ; set temperature limit for heater 0 to 140C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q100 ; create fan 1 on pin fan1 and set its frequency
      M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
      M950 F2 C"fan2" Q80 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 H2:3 L0.15 X110 B0.3 T40:70 ; set fan 2 value
      G10 P0 X0 Y0 Z0 ; reset tool 0 axis offsets
      G10 P0 R0 S0 ; reset initial tool 0 active and standby temperatures to 0C
      ;tool offsets - stock
      ;G10 P0 X55 Y322 Z-5 ; T0
      ; Filament diameter
      M404 P0 N1.75 D0.4
      ;deselect tools
      T-1
      ;M572 D0 S0.05 ; pressure advance T0
      M501 ; read stored parameters
      M80 ; Turns on the ATX power supply
      M81 ; Turns off the ATX power supply
      • Vetiundefined
        Veti
        the movement is defined in the home scripts.
        post all of them
          sigourosandreas
          Thanks for the help.
          I found the problem as you mentioned
            Might be a good idea to post them anyway. It's possible to change either homing direction or motor direction to accomodate for an incorrect endstop definition.
            Keep in mind that 0,0 origin point should be the front left corner. x+ goes to the right, x- goes to the left, y- goes to the front, y+ goes to the back. If the motors move opposite to this you should change the motor direction. From there the endstop position is either at the high end or low end of travel of the axis. Set with M574 X1 or X2, etc. Then the homing direction in the homing files should move the axis towards the endstop.
