    No heater printing
    1057
    • Kulitorum
      Kulitorum last edited by
      I made a clay extruder for my printer.
      How can I make reprap firmware print without any heater or temperature sensors?
      Does it have a fake heater that I can make always return 200c or something to make the firmware extrude with a cold extruder, or even without temp sensors?
      Thanks.
      • Whitewolf
        Whitewolf last edited by
        Take a look at the gcode wiki you will find commands for cold extrusion
        Exploring the universe wherever the tech blows
        • lars
          lars last edited by
          M302: Allow cold extrudes
          M302 P1
          https://duet3d.com/wiki/G-code#M302:_Allow_cold_extrudes
          • Kulitorum
            ThenI still have to install thermistors, just to give it some kind of temperature reading, but the printer does not have any real need for a temp reading.
            I will install one for now, and suggest that a fake temperature sensor is added to the firmware.
            • Dougal1957
              Dougal1957 last edited by
              instead on installing thermistors you could use a 100K resistor in there place
                If you define your tool as having no heaters in the M563 command, I don't think you should need to use any temperature sensors. Have you tried that?
                • Kulitorum
                  Yes, I tried that. I dont remember what went wrong, but I could not get that to work too.
                  I have installed a thermistor and added M302 P1 to my init code, and that works.
                  Thanks
                    I've just tested the forthcoming RRF 1.18RC1. If you create a tool with no heaters, extrusion does work using G1 E commands. However, DWC 1.17+2 greys out the Extrude and Retract buttons. This appears to be fixed in the beta of DWC 1.19 that chrishamm has given me to test.
                    • Kulitorum
                      Ok, great.
