    Mesh levelling on 3.1.1
    1.4k
    • laelundefined
      lael @fcwilt
      @fcwilt said in Mesh levelling on 3.1.1:
      @lael said in Mesh levelling on 3.1.1:
      I've gone through the entire procedure manually.
      Did you do a G30 prior to the G29 that actually started the probing of the bed?
      yes
      In terms of the nozzle tip, you mean relative to the bed?
      The bed is quite warped, but at the center where I run the G30's for printing etc, it is just the right height above the bed to grip a piece of paper lightly. So I guess ~0.1 or a little less or so.
      • fcwiltundefined
        fcwilt @lael
        @lael
        If you are going to use the G92 Znnn command you should determine as best you can what the actual nozzle position is and use that value.
        Did you correct your G31 command and include the P X Y and Z parameters?
        • laelundefined
          lael
          So what is the relationship between all of the Z points?
          Here is my understanding so far:
          G92 Z0 sets printing 0 - so the firmware is expecting 0 to be where the nozzle should be when putting down the first layer.
          G31 sets the location where the probe will be triggered - so in my case it is a piezo sensor which is triggered when the nozzle impacts the bed. So a -0.7mm makes sense as that is when the nozzle will actually contact the bed?
          Home Z will move the head/bed (bed in my case) to the end stop, which will reference that location as zero.
          Then mesh compensation will apply the additional compensation it has found above or below the Z point. The G30 datum point - sets the location at which the mesh map will be applied from? or does it overrride the G31 in config.g?
          Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @lael
            G30 uses the trigger height from G31
            Usually when you have a probe, you don't use a Z min endstop at all. You use the probe for homing Z and creating the mesh. That way the Z0 reference is always the same based on the probe.
            laelundefined 1 Reply Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @lael
              It's essential that the firmware knows the actual position of the nozzle on the X, Y and Z axes. For the Z axis that position can be set using an end stop or a Z probe. While the end stop references the frame, the Z probe references the bed which is better because any changes due to the heating of the bed are compensated for with each setting of the Z=0 datum.
              Not exactly. When the Z probe is triggered the Z trigger height value in G31 is used to set the firmware's Z position value so that the firmware "knows" where the nozzle is positioned on the Z axis. If the value in G31 is wrong the firmware's "knowledge" of the nozzle position will be wrong.
              Just as the G31 Z trigger height value is used to set the Z position value when the Z probe is triggered the G92 Znnn is used to set the Z position value when the end stop is triggered. Naturally the nnn value needs to match the actual Z position when the end stop is triggered.
              The G30 sets the Z=0 datum. The G29 probing is determining the Z difference at each probe point in reference to the point used for G30 - the differences can be plus or minus. Thus the same XY position must always be used when setting the Z=0 datum with G30.
              Since the Z=0 datum determines the plus/minus Z values in the height map it is necessary to use G30 when creating the height map AND when loading the height map.
              If for some reason the Z=0 datum used when creating the height map differs significantly from the Z=0 datum used when later loading the height map you can get the error about the Z offset.
              I hope that covers it and I have'nt made any errors - it's late here.
              laelundefined 1 Reply Last reply Reply Quote 1
              • laelundefined
                lael @fcwilt
                @fcwilt So if no G30 was used prior to loading a mesh map, what does it use as the datum? the value from G31, or maybe the current zero point?
                • laelundefined
                  lael @Phaedrux
                  @Phaedrux I know a lot of people don't, however, with a piezo they will trigger during travel moves as well, so while good as a probe are an unreliable z stop.
                  Plus, the way I have it set up if the probe fails, the optical end stop will stop the machine. If that sensor fails in the heated chamber, then the estop connected limit switch will prevent hardware damage.
                    That's fine. There's nothing wrong with using both an endstop and a probe. The important thing to avoid unintended offsets with the mesh, is to ensure the probe is used to set Z0 before the mesh is created or loaded. So as long as you're doing a G30 before G29 or G29 S1, you're good to go.
                    If no G30 is used before loading the heightmap the Z position is defined by your endstop if that's what you've used to home it. In other words, it'll be whatever the distance is between your nozzle tip and bed surface when the endstop is triggered.
                    • laelundefined
                      lael
                      ok, so I've modified start.g to include a G92 Z0 using the probe as follows:
                      G28 ;home all axis
                      changes here:
                      G0 X130 Y130 Z10 ; go to bed center, 10mm above
                      G30 S-1 ; test - send to probe contact with bed
                      G92 Z0 ; set Z0 to probe contact on bed (hoping that then G30 will account for actual bed height...)
                      G30 ; probe for datum ref point
                      G29 S1 ; Load Grid Compensation
                      T0 ; Selects Tool 0 (active temp)
                      M703 ; Ensure filament specific settings are loaded
                      G1 X10 Y10 ; move close to origin
                      That seems to be giving the expected results from mesh levelling, but is that a bad idea?
                        As long as that matches what you do before you create the mesh it should be fine.
                        Not sure why you'd have that in start.g, but the G30 afterwards is what matters.
