    Weird height map - BLTouch
    • Zestundefined
      Zest
      I finally got my machine running and I'm ALMOST there with the mesh leveling. I can get it to probe 25 points but the resulting map is obviously not right.
      Here are my bed.g and config.g files. I copied most of the important bits from the other threads. The result I get is from clicking the bed compensation button in the GUI. I know I'm missing something obvious but I have no idea what it is.
      The printer is a wanhao I3 with a 190x200 bed. I think it has something to do with the grid… Also the deviation between points seems awfully high.
      ;bed.g taken from another user
      M557 X40:180 Y40:180 S28    ; Define grid, edit this
      T0                          ; Select tool 0
      G91                 ; Relative mode
      G1 Z10 F150            ; Make sure everything clears the bed
      ; ------------ Home Z ---------------------
      G90                         ; Absolute mode
      G1 X110.5 Y72 Z6 F4000      ; Home at center of bed, my offsets are X-22 and Y44, edit these
      M401                        ; Deploy probe
      G30                         ; Home Z-axis
      ;----------- Mesh Level ------------------
      G29                         ; Start mesh level
      M374                        ; Save results, but this might not be necessary
      M402                        ; Retract probe
      G1 X20 Y20 Z10 F3000        ; Dock position
      ;config.g
      ; DuetWIFI config
      M111 S0                             ; Debug off
      M550 DuetHaoi3                      ; Machine name (can be anything you like)
      M551 i3                             ; Machine password (currently not used)
      M552 S1                             ; Enable WiFi
      M555 P2                             ; Set output to look like Marlin
      M575 P1 B57600 S1                   ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      ; Movement
      G21                                 ; Work in millimetres
      M569 P0 S0                          ; Drive 0 goes backwards
      M569 P1 S0                          ; Drive 1 goes backwards
      M569 P2 S1                          ; Drive 2 goes forwards
      M569 P3 S1                          ; Drive 3 goes forwards
      M906 X855 Y855 Z670 E1020           ; Set motor currents (mA)
      M201 X1000 Y800 Z100 E5000          ; Accelerations (mm/s^2)
      M203 X12000 Y12000 Z400 E3000       ; Maximum speeds (mm/min)
      M566 X600 Y600 Z18 E20              ; Maximum jerk speeds mm/minute
      M574 X1 Y1 Z0 S0                    ; set homing switch configuration (No z switch, use z probe with M558)
      M208 X200 Y200 Z180                 ; set axis maxima and high homing switch positions (adjust to suit your machine)
      M208 X-8 Y-8 Z-0.5 S1               ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
      M92 X80 Y80 Z400 E96.780                ; set axis steps/mm
      M350 X128 Y128 Z128 E128 I1             ; set 16x microstepping with interpolation
      G90                                 ; Send absolute coordinates...
      M83                                 ; ...but relative extruder moves
      ; M558 P1 X0 Y0 Z1 H3 F200 T5000      ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
      ; G31 P500 X-45 Y45 Z0.66             ; set threshold and offsets
      ; BLtouch stuff
      M307 H3 A-1 C-1 D-1 ; use pin 3 on header for bltouch
      M558 P5 X0 Y0 Z1 H5 F100 T2000  ;  probe type and use probe for homing z *T2000 travel speed*
      G31 X-22 Y-44 Z2.18  P25 ; set probe height  ** edit this **
      ; Heaters + Thermistors
      M305 P0 T100000 B3950 R4700 H0 L0   ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B4388 R4700 H0 L0   ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M307 H0 A193 C719.9 D8.7 B0         ; bed heater settings
      M307 H1 A472.7 C214.3 D6.5 B0          ; extruder heater settings
      M570 S120                           ; Increase to allow extra heating time if needed
      M106 P1 T45 H1
      M106 P2 T45 H1                      ; Run Coldend-Fan and electronics fan at 45°C
      ; T0
      M563 P0 D0 H1                       ; tool 0 uses extruder drive 0 and heater 1
      G10 P0 S0 R0 X0 Y0                  ; set tool 0 temperatures and offsets
      ; the end
      M556 S100 X0 Y0 Z0                  ; Put your axis compensation here
      T0                                  ; Select the first head
      RepRapFirmware height map file v1, mean error -0.18, deviation 1.39
      xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
      40.00,180.00,40.00,180.00,-1.00,28.00,6,6
       -2.166, -1.154, -0.195,  0.771,  1.697,      0
       -2.196, -1.150, -0.161,  0.810,  1.731,      0
       -2.193, -1.153, -0.155,  0.810,  1.745,      0
       -2.161, -1.118, -0.120,  0.837,  1.780,      0
       -2.161, -1.117, -0.118,  0.844,  1.786,      0
            0,      0,      0,      0,      0,      0
        1. Is the print bed level?
        2. If you have dual Z motors, are they both moving when the bed is being probed?
        • number40fanundefined
          number40fan
          I had a result like that because I didn't run G32 first.
