    standby and active temperatures -273.1 on startup
    Duet Web Control
    • Visionaryundefined
      Visionary
      My DWC shows following on startup:
      How can I fix it so that it has 0 on all active/standby temperatures?
      Also it would be good to also have heater 1 off on startup?
      3D-printer part collector || https://grabcad.com/eetu-4/models
      Stephen6309undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @Visionary
        @Visionary Add a G10 with the standby temp for that heater/hotend in config.g. Something like G10 P1 S0 R0.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Tool_Offset_and_Temperature_Setting
          dc42 administrators @Visionary
          @Visionary said in standby and active temperatures -273.1 on startup:
          As @Stephen6309 says.
          If you remove the T0 command from config.g then it won't be active. But you will need to either ensure that the GCode files that you print include T0 or another tool selection command at the start, or create a start.g file containing the T0 command.
          Visionaryundefined 1 Reply Last reply Reply Quote 0
            Visionary @dc42
            @dc42 @Stephen6309
            Ok, thanks.
            G10 command for the other tool missed R0 and S0 and now it shows better values (0).
            Leaving heater 1 active seems easier so I think I will leave it as it is.
