    Hot Melt Glue Gun extruder
    Using Duet Controllers
    • Duetfan223undefined
      Duetfan223
      Hello
      I want to attach an inexpensive 110v hot melt glue gun to my printer. The idea is to wait about 5 minutes for the nozzle to reach proper temperature and then hit "go" on the print.
      Is there a way to disable or circumvent the heater / thermistor setup on the Duet 085, so that I can use the 110v hot glue gun instead?
      (Worth noting: I understand the danger involved with what I'm asking about and accept full responsibility for any outcome. Thank you in advance for any concerns)
      • alankilianundefined
        alankilian
        How about setting the extruder temperature at zero and allowing cold extrusions?
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
        Will that work for you?
          Duetfan223
          Sounds good, will try this out. Thank you Alan!
            alankilian
            @Duetfan223 said in Hot Melt Glue Gun extruder:
            Send photos!
              If you don't include any heaters in your M563 tool configuration command in config.g then cold extrusion will be allowed automatically.
