    Duex Heater LED lit....unused
    • TampaPrinter
      TampaPrinter last edited by TampaPrinter
      Hello all. Today I added a duex5 to my corexy in preparation of going to triple Z. Moved the BLTouch, moved X,Y and current dual Z to the Duex (keeping stepper wires away from heater line seemed like good practice). Changed config.g & home files and all seems to work well. There is an LED lit on the Duex that doesn’t seem like it should be. The LED above the E6 heater is lit....though E6 is not called for in the config. Its not lit on startup, but lights after home and stays lit. It’s also the only LED lit on the Duex. I cant find an LED explanation on the Duex like on the Duet2wifi dozuki so thought I would ask if this is normal and what that LED is for. Would also be nice to get a more experienced set of eyes on my config....just to be sure I have not missed something. I have two duet machines now, but I'm still pretty green.
      SkGo2 Corexy-Duet2wifi-Duex5-PanelDue7-HemeraVolcano
      CR10V2 -Duet2wifi-Linear-HemeraVolcano
      • TampaPrinter
        config.g
        ; generated by RepRapFirmware Configuration Tool v3.1.10 on Mon Dec 07 2020 13:07:39 GMT-0500 (Eastern Standard Time)
        M550 P"SK-Go2" ; set printer name
        M669 K1 ; select CoreXY mode
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        ; panel due
        M575 P1 S1 B57600 ;activates panel due display
        M569 P0 S1 ; physical drive 0 goes forwards (X)
        M569 P1 S1 ; physical drive 1 goes forwards (Y)
        M569 P2 S1 ; physical drive 2 goes forwards (Z)
        M569 P3 S1 ; physical drive 3 goes forwards (extruder)
        M569 P4 S1 ; physical drive 2 goes forwards (Z on E1)
        M584 X9 Y8 Z7:5 E3 ; wws two Z motors connected to driver outputs Z and E1
        M671 X-36:363 Y0:0 S3 ; wws leadscrews at left (connected to Z) and right (connected to E1) of X axis
        M92 X200.00 Y200.00 Z400.00 E393.00 ; set steps per mm
        M566 X900.00 Y900.00 Z34.00 E120.00 ; wws set JERK maximum instantaneous speed changes (mm/min)
        M203 X22000.00 Y22000.00 Z2000.00 E5400.00 ; set maximum speeds (mm/min)
        M201 X2000.00 Y2000.00 Z40.00 E1000.00 ; wws set accelerations (mm/s^2)
        M906 X1300 Y1300 Z800 E850 I20 ; wws set motor currents (mA) and motor idle factor in per cent
        M593 F41.2 ; wws cancel ringing at 41.2Hz
        M84 S30 ; Set idle timeout
        M208 X-1 Y-2 Z0 S1 ; set axis minima
        M208 X324 Y329 Z304 S0 ; set axis maxima
        M574 X1 S3 ; configure sensorless endstop for low end on X
        M574 Y1 S3 ; configure sensorless endstop for low end on Y
        M574 Z1 S2 ; configure Z-probe endstop for low end on Z
        ;M915 X Y S3 R0 F0 ; wws s1 sets up the last main command needed for sensorless homing
        M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H3 F600 T21000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P25 X35 Y-4 Z3.08 ; set Z probe trigger value, offset and trigger height (Z-smaller number raises nozzle)
        M557 X35:315 Y15:315 S31 ; define mesh grid
        M376 H3 ; wws define fade height
        M307 H0 A314.6 C690.4 D3.6 S1.00 V24.1 B0 ; disable bang-bang mode for the bed heater and set PWM limit
        M143 H0 S110 ; set temperature limit for heater 0 to 110C
        M308 S1 P"e0temp" Y"pt1000" ; wws configure sensor 1 as pt1000 on pin e0temp
        M307 H1 A893.3 C322.6 D5.3 S1.00 V24.0 B0 ; wws 64w BZAMD disable bang-bang mode for heater and set PWM limit
        M143 H1 S450 ; set temperature limit for heater 1 to 450C
        M950 F0 C"fan0" Q500 ; PART COOLING create fan 0 on pin fan0 and set its frequency
        M950 F1 C"fan1" Q500 ; HOTEND create fan 1 on pin fan1 and set its frequency
        M950 F2 C"fan2" Q500 ; fan 2 - driver cooling 40mm on during print only
        M106 P2 S1 H1 T45 ; fan 2 - thermostatic control
        M950 F7 C"duex.fan7" Q500 ; DUEX driver cooling 40mm on during print only
        M106 P7 S1 H1 T45 ; fan 7 - thermostatic control
        M563 P0 S"Hemera" D0 H1 F0 ; define tool 0
        M122
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later + DueX5
        Board ID: 08DLM-996RU-N85S4-7JKDL-3S46M-1SBHP
        Used output buffers: 8 of 24 (21 max)
        Static ram: 23460
        Dynamic ram: 73888 of which 176 recycled
        Never used RAM 14556, free system stack 186 words
        Tasks: NETWORK(ready,182) HEAT(blocked,295) DUEX(blocked,35) MAIN(running,466) IDLE(ready,19)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:01:39 ago, cause: power up
        Last software reset at 2021-01-16 16:08, reason: User, GCodes spinning, available RAM 14488, slot 1
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU temperature: min 28.2, current 33.2, max 33.7
        Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 0, standstill, SG min/max not available
        Driver 1: position 0, standstill, SG min/max not available
        Driver 2: position 0, standstill, SG min/max not available
        Driver 5: position 0, standstill, SG min/max not available
        Driver 6: position 0, standstill, SG min/max not available
        Driver 7: position 0, standstill, SG min/max not available
        Driver 8: position 0, standstill, SG min/max not available
        Driver 9: position 0, standstill, SG min/max not available
        Driver 10: position 0
        Driver 11: position 0
        Date/time: 2021-01-16 16:17:24
        Cache data hit count 123162317
        Slowest loop: 88.75ms; fastest: 0.20ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.9ms, write time 2.2ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 27.77ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address 👽
          WiFi Vcc 3.36, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 24288
          WiFi IP address 👽
          WiFi signal strength -56dBm, mode none, reconnections 0, sleep mode modem
          Clock register ffffffff
          === DueX ===
          Read count 1, 0.60 reads/min
          Phaedrux Moderator @TampaPrinter last edited by
          @TampaPrinter said in Duex Heater LED lit....unused:
          Post your homing files?
            dc42 administrators @TampaPrinter last edited by
            @TampaPrinter, the E6 Heater and PWM5 outputs on the DueX share the same control signal. So the E6 Heater led lights up when you first send a control signal to the BLTouch.
            TampaPrinter 1 Reply Last reply Reply Quote 0
            • TampaPrinter
              TampaPrinter @dc42 last edited by
              @dc42 I thought it might be something like that! Thanks much for the clarification. It's all working very well!
