    Duet 2 ethernet connection
    41
    • usas12
      usas12 last edited by
      I have just installed a duet 2 Ethernet board. I am unable to get this board to be recognized by my router.
      I have gone through the process of connected to my PC via the usb and that works. I can connect to the board via the port no problems. I connect the Ethernet cable and enable networking and the port lights come on. I set the board to auto assign an IP and nothing happens. I check my router for active IP connections on the network and i get nothing from the duet. I tried to assign an IP for the board and still, I get nothing on the router and nothing in browser. I've checked the cable and it's functioning correctly. I'm sure you can already tell, I'm not a real computer guy. What am i doing wrong here??
      • Veti
        Veti last edited by
        while connected with usb send M552 to see the assigned ip.
        • usas12
          yes done that, it does not assign an IP. comes back with
          " Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0"
          and does not update from there, doesn't get detected by the router
          • Veti
            Veti last edited by
            can you manually assign an ip and test.
            like this but adjusted for your network
            M552 P192.168.1.20 S1 ; enable network and set IP address
            M553 P255.255.255.0 ; set netmask
            M554 P192.168.1.254 ; set gateway
            • usas12
              @Veti said in Duet 2 ethernet connection:
              P192.168.1.20
              SENT: M552 P192.168.1.20 S1
              READ: ok
              SENT: M553 P255.255.255.0
              READ: ok
              SENT: M554 P192.168.1.254
              READ: ok
              SENT: m522
              READ: M522 command is not supported
              READ: ok
              SENT: m554
              READ: Gateway: 192.168.1.254
              READ: ok
              SENT: m552
              READ: Network is enabled, configured IP address: 192.168.1.20, actual IP address: 192.168.1.20
              READ: ok
              Still no connection detected by the router. Nothing in the browser.
              As i mentioned in the first post. The board is responding to commands via a usb connection just fine. But nothing is passing via Ethernet. The router is not recognizing it and the pc doesn't either if i connect it directly via Ethernet
              • Veti
                Veti last edited by
                whats the ip of your pc? just checking
                usas12 1 Reply Last reply Reply Quote 0
                • usas12
                  usas12 @Veti last edited by usas12
                  @Veti 192.168.1.1
                  • Veti
                    Veti last edited by
                    can you connect the duet directly to the pc and check with those settings?
                    • usas12
                      @Veti Nothing detected same as before
                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-09b1
                      • A Former User
                        Long shot, but check the MAC address with M540? (could also try setting one if comes back all 1s or 0s, but make sure the U/L bit is high (2nd digit of first octet being 2, 6, A or E iirc) see https://duet3d.dozuki.com/Wiki/Gcode#Section_M540_Set_MAC_address for syntax)
                        If the MAC address looks good then I guess Wireshark to sniff the DHCP negotiation is the simplest way of telling which side is failing. (but as only parts of the traffic is broadcast the best would be to run tcpdump on the rotuer if its running OpenWRT or similar firmware. A managed switch to mirror the traffic is also a good option. Lastly having only your computer and the Duet on a switch that is otherwise not connected and running both Wireshark and DHCP server on your computer before powering up the Duet might give you some insight still)
                        • usas12
                          MAC: be:63:50:4b:52:38 ???
                          A Former User 1 Reply Last reply Reply Quote 0
                          • A Former User
                            A Former User @usas12 last edited by
                            @usas12 said in Duet 2 ethernet connection:
                            be:63:50:4b:52:38
                            its already an locally administered address, but otherwise looks valid - it could be the router is refusing to serve a local address but I think that would be a bug in the router.
                            • usas12
                              @bearer I have other devices here (not currently connected) when I connect them the router sets an IP no problems. It's just the duet that's having the problem
                              • usas12
                                SOLVED, ran it through a switch and detected just fine. Also updated firmware but doubt that was it
