    Upgraded to duet 3 and get Unknown usb device
    Firmware installation
    100
    • patterson6
      patterson6 last edited by
      So i upgraded to duet 3 from duet 2 and i get an Unkonwn Usb Device (device Descriptor request failed) in device manager. I tried to install the new driver but i just get back the best drivers for your device are already installed.
      I put in my Sd card from the duet 2 and get the same thing. Is my board bad?
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @patterson6 last edited by
        @patterson6 Not neccesarily. You need to try different usb cables and usb ports.
        • patterson6
          The same usb cable and port used to work with the duet 2. I did try different ports same thing.
            Unless you wiped the firmware with the reset jumpers it ships with firmware already installed. It's an ethernet device so you should be able to connect it to your network, and provide it an SD card with the DWC files in /www and a config file set in /sys and as long as you have it configured to obtain a DHCP IP address you should be able to reach it on the network.
            Why do you need to connect it to your PC in the first place?
            The Duet 3 draws a bit more power I think and sometimes usb ports that worked with older boards simply don't work with the Duet 3. Sometimes using a USB hub works well, ideally a powered hub.
              Duet 3 MB6HC uses a high speed USB port, which is fussier about the USB cable than Duet 2.
              • patterson6
                Thanks everyone! It works! I Removed the duet 3 from the printer and just used the 3 foot USB cable and it worked. I guess it didn't like the 12ft USB extension cable i was using.
                  dc42 administrators @patterson6 last edited by
                  @patterson6 said in Upgraded to duet 3 and get Unknown usb device:
                  I find that USB extension cables don't work with the MB6HC for programming with Bossa, although I have managed to use them for controlling the board using YAT.
                  • patterson6
                    if anyone is looking for a longer cord this 15 ft works for me
                    https://www.amazon.com/gp/product/B01GEDOR2S/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
