    Not showing hotend under tools
    Firmware installation
    • Alucardi
      Alucardi last edited by Alucardi
      I am only seeing my bed under tools. Thermistor i s connected to TEMP 1 and OUT 1. What could be the issue? Is was working fine on my duet 2 wifi. Config are added.
      config.g
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @Alucardi last edited by Stephen6309
        @Alucardi For my Duet 3 6HC and Mini, bed power is OUT0 and the thermister is on TEMP0. For the Duet 3 6HC, don't forget to supply power to OUT0 Power In.
        OUT1/TEMP1 are used for my T0.
        Alucardi 1 Reply Last reply Reply Quote 0
        • Alucardi
          Alucardi @Stephen6309 last edited by
          @Stephen6309 I have triple checked the ports I connected the hotend to. Even if there was an issue would I not see the hotend as a tool in the web interface?
            You have no tools defined.
            Alucardi 2 Replies Last reply Reply Quote 0
            • Alucardi
              Alucardi @Phaedrux last edited by
              This post is deleted!
              • Alucardi
                Alucardi @Phaedrux last edited by Alucardi
                @Phaedrux how do i do that? why was it not configured in the configurator? The bed is showing up fine without me having tools set. So why does the hotend not show? I tried M563 but it does nothing to add that under tools.
                  The web interface is showing tools. A tool is made up of a heater, a motor, and a fan. The bed heater and chamber heater are treated a bit differently. A tool heater without a tool is useless.
                  Here's an example guide for going through the configurator with the mini5+
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
