    Compile errors "undefined reference to 'lrintf' for RRF2
    Firmware installation
    735
    • jmlundefined
      jml
      I am just trying to Build the code. CoreNG and FreeRTOS build fine. Then RepRapFirmware had a bunch of path issues which I fixed.
      But now I get this error when compiling:
      CartesianKinematics.cpp:(.text._ZNK19CartesianKinematics21CartesianToMotorStepsEPKfS1_jjPlb+0x20): undefined reference to `lrintf'
      plus many other similar errors for lrintf, pow, cosf, sinf, sqrtf, vApplicationTickHook, and maybe more.
      I'm a bit of a novice, so any help is greatly appreciated!
      • jmlundefined
        jml
        If it helps, in the Cross G++ Linker settings, next to All Options is this editable text:
        -L"/Users/John/Desktop/eclipse-workspace/CoreNG/SAM4E8E_RTOS" -L"/Users/John/Desktop/eclipse-workspace/FreeRTOS/SAM4E" -Os --specs=nano.specs -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -T"/Users/John/Desktop/eclipse-workspace/CoreNG/variants/duetNG/linker_scripts/gcc/flash.ld" -Wl,-Map,"/Users/John/Desktop/eclipse-workspace/RepRapFirmware/Duet2_RTOS/Duet2CombinedFirmware.map"
        • jmlundefined
          jml
          If someone has compiled RRF2 before, let me know what the command is right after this:
          Building target: Duet2CombinedFirmware.elf
          Invoking: Cross G++ Linker
          Mine is really long and starts with:
          arm-none-eabi-gcc -L"/Users/.........
          and ends with:
          ....... ./src/ZProbeProgrammer.o -lCoreNG -lFreeRTOS
          I have a feeling the lower case L's arguments are not right, but not sure.
          • jmlundefined
            jml
            After the "-l" , should it be "CoreNG" and "FreeRTOS"? Or should it be an actual directory to CoreNG and the directory to FreeRTOS?
              The -L options are the library paths, as set in the Libraries tab in the linked settings. The -l options are the library file names, also set in the Libraries tab.
              The undefined symbols you listed are mostly supplied by the C maths library, which should have been installed with Gnu ARM Developer Tools and should be included by the linker automatically.
              Which versions of Eclipse and Gnu ARM Developer Tools are you using?
              • jmlundefined
                jml
                Thank you dc42. On Mac, Eclipse Version: 2020-09 (4.17.0). The arm developer tools thing in my downloads folder is named:
                gcc-arm-none-eabi-6-2017-q2-update
                • jmlundefined
                  jml
                  However, when I look in Duet2CombinedFirmware.map, I see a line for llrint with the following text:
                  llrint /usr/local/Caskroom/gcc-arm-embedded/7-2018-q2-update/gcc-arm-none-eabi-7-2018-q2-update/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/libm.a(lib_a-s_llrint.o)
                  edit: i was looking at an old file
                    dc42 administrators @jml
                    @jml, try using a later version of Gnu ARM Developer Tools, but not the very latest one because that is a new major compiler version. The 2019 q4 version should be about right.
                    • jmlundefined
                      jml
                      I have downloaded it and unzipped it. Then in RepRapFirmware Properties, C/C++ Build > Settings > Cross Settings, I changed the path to be to the unzipped folder:
                      /Users/John/Downloads/gcc-arm-none-eabi-9-2019-q4-major
                      (should there be a "/bin" at the end?)
                      However, I get the exact same errors.
                      • jmlundefined
                        jml
                        Also, should i be making the Cross Settings path to:
                        /Users/John/Downloads/gcc-arm-none-eabi-9-2019-q4-major/bin
                        for CoreNG, FreeRTOS, and RRF? I noticed FreeRTOS had a different path:
                        /usr/local/bin
                          @jml said in Compile errors "undefined reference to 'lrintf' for RRF2:
                          /usr/local/bin
                          For all projects except the WiFiServer projects, the files on github set it to {ArmGccPath}. You should not have changed that. ArmGccPath is a build variable set up in Window->Preferences, which you should set to that gcc-arm-none-eabi-9-2019-q4-major/bin folder as per the build instructions.
                          jmlundefined 1 Reply Last reply Reply Quote 0
                          • jmlundefined
                            jml
                            Ok they are no all set to gcc-arm-none-eabi-9-2019-q4-major/bin
                            Still the same errors persist. Here is another example error:
                            /Users/John/Downloads/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: ScaraKinematics.cpp:(.text._ZNK15ScaraKinematics21MotorStepsToCartesianEPKlPKfjjPf+0x7e): undefined reference to `sinf'
                            If I actually go to the paths, I do see the right things in those folders. I'm on Mac by the way, so I wonder if that has anything to do with it?
                            • jmlundefined
                              jml @dc42
                              My bad - i was following old instructions that mentioned setting it to /usr/local/bin
                              • jmlundefined
                                jml
                                Anyway, I've tried the new 2019 q4 major update, and it is not improving the results at all. Still lots of the same error like undefined reference to `pow'. Hmmmm
