    RRF 3.2: Failed to start Duet Control Server
    Firmware installation
    1
    • MartinNYHC
      MartinNYHC last edited by
      Used my printer yesterday. When I switch it on again this morning I got the followiwng Syslog error message:
      Jan 18 09:04:45 duet3 DuetControlServer[744]: [info] Settings loaded
      Jan 18 09:04:46 duet3 DuetControlServer[744]: [info] Environment initialized
      Jan 18 09:04:46 duet3 DuetControlServer[744]: [fatal] Could not connect to Duet (Board is not available (no header))
      Jan 18 09:04:46 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
      Jan 18 09:04:46 duet3 systemd[1]: Failed to start Duet Control Server.
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Request starting HTTP/1.1 GET http://192.168.255.30/rr_connect?password=reprap&time=2021-1-18T9%3A4%3A46 application/json
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: DuetWebServer.Middleware.CustomEndpointMiddleware[0]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       No endpoint found for GET request via /rr_connect
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Request finished in 3.8272ms 404
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Request starting HTTP/1.1 GET http://192.168.255.30/machine
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Cors.Infrastructure.CorsService[5]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       CORS policy execution failed.
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Cors.Infrastructure.CorsService[6]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Request origin http://192.168.255.30 does not have permission to access the resource.
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
      Jan 18 09:04:46 duet3 DuetWebServer[621]: fail: DuetWebServer.Controllers.WebSocketController[0]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       [WebSocketController] DCS is not started
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 13.8286ms
      Jan 18 09:04:46 duet3 DuetWebServer[621]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
      Jan 18 09:04:46 duet3 DuetWebServer[621]:       Request finished in 23.8999ms 101
      Jan 18 09:04:46 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
      Jan 18 09:04:46 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 7.
      Jan 18 09:04:46 duet3 systemd[1]: Stopped Duet Control Server.
      Jan 18 09:04:46 duet3 systemd[1]: Starting Duet Control Server...
      Any ideas please?
      • MartinNYHC
        My fault. I still had an empty SD card inserted into the Duet 3 🤕
        Sorry for that.
