    Heated bed not registering RR 3.2
    • usas12undefined
      usas12
      Hi guys,
      Next problem. My heated bed does not seem to be registering, and is not displaying in the tool menu on the web interface. I'm running RR 3.2 on an E3D toolchanger. Checked the wiring all seems to be fine there, is wired through a SSR. Once again, your help is appreciated.
      Regards
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M550 P"ToolChanger" ; Set machine name
      M552 S1 ; Enable Networking
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M667 S1 ; Select CoreXY mode
      ; Drive direction
      M569 P0 S0 ; Drive 0 X
      M569 P1 S0 ; Drive 1 Y
      M569 P2 S1 ; Drive 2 Z
      M569 P3 S0 ; Drive 3 E0
      M569 P4 S0 ; Drive 4 E1
      M569 P5 S1 ; Drive 5 E2
      M569 P6 S1 ; Drive 6 E3
      M569 P7 S0 ; Drive 7 COUPLER
      M569 P8 S0 ; Drive 8 UNUSED
      M569 P9 S0 ; Drive 9 UNUSED
      M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
      ;M208 X-35:328.5 Y-49:243 Z0:300 C0:500 ; Set axis maxima & minima
      M208 X-185:178.5 Y-149:143 Z0:300 C0:500 ; Set axis maxima & minima
      M92 X100 Y100 Z1600 C200 E834:834:834:834 ; Set steps per mm assuming x16 microstepping
      M350 E16:16:16:16 I1 ; Configure microstepping with interpolation
      M350 C16 I1
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M566 X400 Y400 Z8 C2 E200:200:200:200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X35000 Y35000 Z1200 C10000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
      M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
      M906 X2000 Y2000 Z1330 C500 E1600:1600:1600:1600 I30 ; Set motor currents (mA) and motor idle factor in percent
      M913 C50
      M84 S120 ; Set idle timeout
      M574 X1 Y1 S3 ; Set X / Y endstop stall detection
      M574 Z0 ; No Z endstop
      M574 C1 S3 ; Stall detect coupler at low end of its range
      ; Z probe
      M558 P8 C"zstop" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      ;M557 X10:290 Y20:180 S40 ; Define mesh grid
      M557 X-140:140 Y-80:80 S40 ; Define mesh grid
      ;Stall Detection
      M915 C S6 F0 H200 R4700 ; Coupler
      ;Stall Detection
      M915 X Y S3 F0 H400 R4700 ; X / Y Axes
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 ; Set thermistor
      M950 H0 C"bedheat" T0 ; Bed heater
      M143 H0 S225 ; Set temperature limit for heater 0 to 225C
      M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 ; Set thermistor
      M950 H1 C"e0heat" T1 ; Extruder 0 heater
      M143 H1 S300 ; Set temperature limit for heater 1 to 300C
      M308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8 ; Set thermistor
      M950 H2 C"e1heat" T2 ; Extruder 0 heater
      M143 H2 S300 ; Set temperature limit for heater 2 to 300C
      M308 S3 P"e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8 ; Set thermistor
      M950 H3 C"duex.e2heat" T3 ; Extruder 0 heater
      M143 H3 S300 ; Set temperature limit for heater 3 to 300C
      M308 S4 P"e3temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 ; Set thermistor
      M950 H4 C"duex.e3heat" T4 ; Extruder 0 heater
      M143 H4 S300 ; Set temperature limit for heater 4 to 300C
      M563 P0 S"T0" D0 H1 F2 ; Define tool 0
      G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
      G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C
      M563 P1 S"T1" D1 H2 F4 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
      G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C
      M563 P2 S"T2" D2 H3 F6 ; Define tool 2
      G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
      G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C
      M563 P3 S"T3" D3 H4 F8 ; Define tool 3
      G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
      G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C
      ; Fan0 output is not used
      M950 F1 C"fan1"
      M950 F2 C"fan2"
      M950 F3 C"duex.fan3"
      M950 F4 C"duex.fan4"
      M950 F5 C"duex.fan5"
      M950 F6 C"duex.fan6"
      M950 F7 C"duex.fan7"
      M950 F8 C"duex.fan8"
      M106 P1 S255 H1 T70 ; T0 HE
      M106 P2 S0 ; T0 PCF
      M106 P3 S255 H2 T70 ; T1 HE
      M106 P4 S0 ; T1 PCF
      M106 P5 S255 H3 T70 ; T2 HE
      M106 P6 S0 ; T2 PCF
      M106 P7 S255 H4 T70 ; T3 HE
      M106 P8 S0 ; T3 PCF
      M593 F50 ; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
      M376 H15 ; bed compensation taper
      ;tool offsets
      G10 P0 X-9 Y39 Z-5 ; T0
      G10 P1 X-9 Y39 Z-5 ; T1
      G10 P2 X-9 Y39 Z-5 ; T2
      G10 P3 X-9 Y39 Z-5 ; T3
      ; Bowden tubes are ~700mm long so PA almost certainly needs to be increased
      M572 D0 S0.2 ; pressure advance T0
      M572 D1 S0.2 ; pressure advance T1
      M572 D2 S0.2 ; pressure advance T2
      M572 D3 S0.2 ; pressure advance T3
      • fcwiltundefined
        fcwilt
        You are missing a M140 which needs to placed after the M950 but before the M143 for your first heater.
        M140 specifies which heater is use for the bed.
        M140 H0 should do the job.
        usas12undefined 1 Reply Last reply Reply Quote 0
        • usas12undefined
          usas12 @fcwilt
          @fcwilt said in Heated bed not registering RR 3.2:
          M140 H0
          Legend, that did the trick. Thank you
          • fcwiltundefined
            fcwilt
            Glad to hear it is working.
