    Axis limits
    My Duet controlled machine
    • MRJEONundefined
      MRJEON
      For example minimum axis limit (example-x axis)
      If this is 20, is the origin of the x-axis 20?
      • Dad003undefined
        Dad003
        axis limit is generally the maximun space you can move , if you put x20 y30 z50 it mean that the maximun you can print it a cube of 20x30x50 it the total space you have
        • MRJEONundefined
          MRJEON
          For example, the minimum value is
          x 20 y20 z0.2
          Maximum value
          x 100 y 100 z 10
          What if it is?
          • fcwiltundefined
            fcwilt @MRJEON
            @MRJEON said in Axis limits:
            Define "origin".
            The bed on my printer is a piece of tool plate 310x310.
            The printing surface is a magnetically secured piece of flexible steel 300x300.
            I prefer to have X=0 Y=0 at the center of the bed so I set X/Y min to -150 and max to +150.
            The maximum range of motion for X and Y actually is about -160 to +160.
            I confine printing to 295x295 to allow for variations in the placement of that 300x300 piece of steel.
            Does that answer you question?
            • MRJEONundefined
              MRJEON
              Then, if the minimum value x 0 and the maximum value x 150, is the zero point x 75?
              • fcwiltundefined
                fcwilt @MRJEON
                OK let's use the actual command M208.
                Assuming all other settings are correct...
                • If I use M208 X0:300 Y0:300 then X=0 Y=0 should be the left-front corner and X=300 Y=300 the back-right corner AND X=150 Y=150 the center of the bed.
                • If I use M208 X-150:150 Y-150:150 then X=-150 Y=-150 should be the left-front corner and X=150 Y=150 the back-right corner AND X=0 Y=0 the center of the bed.
                Does that help?
