    Duet 3 MB 6HC with Rpi config problems
    Using Duet Controllers
    • rebel_yell_101undefined
      rebel_yell_101
      All, I have a Duet3 MB 6HC with Rpi 3B V1.2 running SBC mode. I was installing it into an FT-6 printer.
      The problem I'm having seems like my config file and firmware are not being read during startup, as I do not have any tools, axis showing in DWC.
      I first set it up a few months ago on 3.1.1 and the only difference was that the status would say "idle" Mode: FFF.
      I was able to send commands to manually home axis even though they were not showing in DWC.
      Last night I Sudo apt-get update and upgrade to 3.2. thinking maybe the updated firmware might be a fix. Now I'm getting firmware incompatible. I even went back to the RRF configurator and created a new file from scratch with no luck. Any help would be appreciated, I've gone through wiki after wiki and I feel like I'm going down a rabbit hole chasing my tail.
      Please see the photos of my DWC as well as my m122 as requested by @Phaedrux M98 P"config.g" not doing anything today.
      Prior to my update last night when it would connect, I was getting the exact same Bad commands just like on this post by @sol88
      https://forum.duet3d.com/topic/20670/problems-geting-started-with-duet-web-control?_=1611026026749
      m122
      RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12 running on Duet 3 MB6HC
      Board ID: 08DJM-956L2-G43S4-6J9D4-3SN6N-TU66G
      Used output buffers: 1 of 32 (4 max)
      Static ram: 122240
      Dynamic ram: 172460 of which 0 recycled
      Exception stack ram used: 216
      Never used ram: 98300
      Tasks: NETWORK(ready,2044) HEAT(blocked,1208) CanReceiv(suspended,3804) CanSender(suspended,1480) CanClock(blocked,1428) TMC(blocked,232) MAIN(running,4212) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:22 ago, cause: software
      Last software reset at 2021-01-18 23:27, reason: Unknown, spinning module Platform, available RAM 98236 bytes (slot 3)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 23.7, current 24.1, max 24.2
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
      Driver 0: standstill, reads 37854, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 37855, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 37856, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 37857, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 37861, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 37862, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-01-18 23:27:57
      Slowest loop: 5.98ms; fastest: 0.25ms
      Hiccups: 0, FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http* is ready with "M122" in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon* is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      spi is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.52ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      • Ethernet -
        State: 0
        === CAN ===
        Messages sent 26, longest wait 0ms for type 0
        === Linux interface ===
        State: 1, failed transfers: 1
        Last transfer: 19ms ago
        RX/TX seq numbers: 248/248
        SPI underruns 1, overruns 1
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.2.0
        Code buffer space: 4096
        Configured SPI speed: 8000000 Hz
        Full transfers per second: 28.16
        Maximum length of RX/TX data transfers: 3020/768
      Config.g:
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 18 2021 22:45:39 GMT-0500 (Eastern Standard Time)
      M550 P"Duet 3" ; set printer name
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X600 Y300 Z400 S0 ; set axis maxima
      M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"io7.in" ; configure active-high endstop for low end on Z via pin io7.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      T0 ; select first tool
      Cliff
        @rebel_yell_101 said in Duet 3 MB 6HC with Rpi config problems:
        There were some problems with beta12 updating. So you have DWC 3.2 and DSF 3.2, but the firmware flashed on the board itself is 3.0beta12.
        See these steps for updating from beta12
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWC
        rebel_yell_101undefined 1 Reply Last reply Reply Quote 0
          rebel_yell_101
          Ok, where to begin...
          I followed those steps you suggested that was posted on the "getting started with Duet 3". I had no change what so ever.
          I then decided to try resetting the board by windows/bossa flash. I flashed the board with the Duet3Firmware_MB6HC.bin that was with the RRF 3.2, then I tried to update firmware again using the link and instructions on the Getting Started, I got an error:
          M997 S0
          Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3_SBCiap_MB6HC.bin
          I then decided to try all over again but this time back to 3.1.1
          I flashed Duet3Firmware_MB6HC.bin from 3.1.1 to the board via bossa. This time when DWC restarted all my config.g items started working: the printer status, tools, temp chart(see picture)
          ![0_1611286881045_Duet3 1.png](Uploading 100%)
          After seeing the change in DWC with config, I then sent M122 and got the following:
          m122
          RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
          Used output buffers: 1 of 40 (10 max)
          Static ram: 154604
          Dynamic ram: 162584 of which 44 recycled
          Exception stack ram used: 224
          Never used ram: 75760
          Tasks: NETWORK(ready,1980) HEAT(blocked,820) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,5048) IDLE(ready,76)
          Owned mutexes:
          Last reset 00:06:19 ago, cause: reset button
          Last software reset time unknown, reason: User, spinning module GCodes, available RAM 91776 bytes (slot 3)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 32.9, current 35.0, max 35.2
          Supply voltage: min 13.4, current 13.7, max 13.9, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
          Driver 0: standstill, reads 20121, writes 14 timeouts 0, SG min/max 0/0
          Driver 1: standstill, reads 20121, writes 14 timeouts 0, SG min/max 0/0
          Driver 2: standstill, reads 20122, writes 14 timeouts 0, SG min/max 0/0
          Driver 3: standstill, reads 20122, writes 14 timeouts 0, SG min/max 0/0
          Driver 4: standstill, reads 20126, writes 11 timeouts 0, SG min/max 0/0
          Driver 5: standstill, reads 20126, writes 11 timeouts 0, SG min/max 0/0
          Date/time: 2021-01-21 22:17:17
          Slowest loop: 3.85ms; fastest: 0.15ms
          === Storage ===
          Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Segments left: 0
          HTTP* is ready with "M122" in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger* is idle in state(s) 0 0, running macro
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon* is idle in state(s) 0
          Aux2 is idle in state(s) 0
          === Network ===
          Slowest loop: 1.03ms; fastest: 0.01ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
          • Ethernet -
            State: disabled
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages sent 1515, longest wait 0ms for type 0
            State: 0, failed transfers: 1
            Last transfer: 18ms ago
            RX/TX seq numbers: 25619/15050
            Buffer RX/TX: 0/0-0
            Trigger:
            Buffered code: T0 ; select first tool
            ==> 24 bytes
            Executing macro config.g, started by system
          Next stack level
          Full transfers per second: 39.69
          Maximum length of RX/TX data transfers: 3168/620
          The part that stood out to me was the:
          It now said SBC Mode.
          After seeing this I tried updating the firmware to 3.2 again using the: Updating Duet 3 from RRF3.0 Beta 12 to 3.0 Final via DWC and am still getting the error:
          M997 S0
          I feel like I got one step forward then one step back(a different step)
          I believe I will now try the Sudo apt-get update/upgrade again and if that doesn't work i'm thinking of starting fresh with the RPI immage.
          Any thoughts?
          Cliff
            rebel_yell_101 @Phaedrux
            @Phaedrux the photo didn't update in my response.
            Cliff
              Phaedrux Moderator @rebel_yell_101
              I concur.
                rebel_yell_101
                Update. After almost a week of messing with it, I got everything working. BLUF: the only thing that has made sense is that there is a problem with my Raspberri Pi.
                I started by using bossa and reflashing the duet 3... that didn't fix the problem.
                I remembered I had a few Raspberri Pi 3 laying around from other projects as well as I had purchased another duet 3 for my other printer. I decided to swap out one thing at a time, starting with a new SD card.
                I then used the new SD card and started with a fresh Duet Pi image. I was still getting errors/incompatble firmware and Error: M997: Failed to find IAP file /opt/dsf/sd/sys/Duet3_SBCiap_MB6HC.bin
                I went back to follow the https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_from_RRF3_0_Beta_12_to_3_0_Final_via_DWC
                After following that Wiki, it got rid of the incompaable firmware but still said it was missing the Duet3_SBCiap_MB6HC.bin
                I then changed only the Raspberri Pi keeping the same SD card and Duet, and after the sudo updates/upgrades everything was working.
                After that I was done with that duet 3 and SBC setup I decided to setup my other new duet 3 and duplicate what I did as both setups are going into 2 identical printers.
                Well to my surprise, using the Pi3 that I was using on the first setup, I started having the exact same issue on the new duet 3. I then grabbed my last Pi 3 I had and swapped only it and everything worked on that setup.
                So, with all of that I can only conclude that there is something wrong with the original Pi3 I was using however, I do not know what.
                I know not everyone will have extra Duet 3's or SBC's laying around, but this happen to be the fix for me.
                Cliff
                • jonsteinmetzundefined
                  jonsteinmetz
                  Just to let others know, I was having the same problem as the OP. I had to force the update of the firmware using the instructions linked above using the BOSSA method and a connected Pi 4. Once that was done the board was connected and the web UI showed the tools and axes in the dashboard.
                  Thanks everyone.
