    DHT22 not working after update from 3.1.1 to 3.2.0
    658
    • jhalewoodundefined
      jhalewood
      Have a DHT22 (on it's own little PCB w/ a 10k pullup resistor on the board) connected to CS1 and 3.3V on a Duet 6HC
      M308 S2 P"spi.cs1" Y"dht22" A"Filament Temp"            ; define DHT22 temperature sensor
      M308 S3 P"S2.1" Y"dhthumidity" A"Filament Humidity[%]"  ; Attach DHT22 humidity sensor to secondary output of temperature sensor
      On 3.1.1 worked fine
      Since updating to 3.2.0 most of the time it sits at 2000° 2000% RH, though every now and then it'll read correctly and plot ~30s of data before returning to 2000/2000
      Sending:
      m308 s2
      Sensor 2 (Filament Temp) type DHT-temperature using pin (spi.cs1,serial3.tx), reading 2000.0, last error: sensor I/O error, sensor type DHT22
      I wanted to send m308 when it is correctly reporting data, but now I'm typing this, it's not doing it...
      Any thoughts?
      • pkosundefined
        pkos
        I was just about to create a new topic on this - since I see the same issue. It stopped working on 3.2, but 3.1.1 was perfectly fine. I thought for a sec it was the DHT itself (I have another thread on my issues with it) and grabbed a brand new one - but that still didn't work.
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
        • A Former User?
          A Former User
          @jhalewood
          @pkos
          Upgraded (about a few weeks ago when it was official alpha) to RRF3.2 (duet2ethernet-1.0.4) and the 2 dht´s are working fine.
          I have in my config:
          ;chamber:
          M308 S10 P"spi.cs1" Y"dht22"       A"Chamb Temp"     ; define DHT22 temperature sensor
          M308 S11 P"S10.1"   Y"dhthumidity" A"Chamb Humid[%]" ; Attach DHT22 humidity sensor to secondary output of temperature sensor
          ;filament:
          M308 S12 P"spi.cs2" Y"dht22"       A"Fila Temp"      ; define DHT22 temperature sensor
          M308 S13 P"S12.1"   Y"dhthumidity" A"Fila Humid[%]"  ; Attach DHT22 humidity sensor to secondary output of temperature sensor
          You are sure that you do not use S2 & S3 "double" for any other sort (that is why I just picked S10 onwards to avoid coming in conflict with standard other sensors that usually occupy the first few Sx places)?
          Hope that maybe is of any help!
          • pkosundefined
            pkos
            I am sure. I have not changed config at all since starting my other thread.
            All I did was just switch to 3.2.
            Given time - I'll downgrade to 3.1.1 today to see if that helps. The results are always stuck at 2k for both temp and humidity.
            I tried it with a brand new DHT connected directly to the board and the one I have originally mounted inside the enclosure.
            • pkosundefined
              pkos
              One more note - I see @LB - you are using a Duet2ethernet, while we both with @jhalewood are on the Duet 3 6HC. This might be another indication.
              • pkosundefined
                pkos
                Went back to 3.1.1 - DHT22 reports values without any issues.
                • A Former User?
                  A Former User @pkos
                  @pkos
                  Now if other board users can jump in here (E.g. maestro and duet2wifi) we could narrow it down if that is only likely to happen with duet3...
                  • Sotidiiundefined
                    Sotidii
                    Duet 3 6HC -Does not work.
                    • A Former User?
                      A Former User
                      Anybody? This is a serious thing for me as one day I might also try out duet3...
                        This was fixed in release 3.2.2.
