    Solved 24v fan connection on Duet 2 wifi
    341
    • gdefranc
      gdefranc last edited by
      Goodmorning everyone.
      I missed something, and reading the documents I didn't understand.
      • duet 2 wifi;
      • tronxy x5sa;
      • all the fans are 24v two wires.
        Can you explain the connection I have to make with the radiator and hotend cooling fans to be controlled from the web console and gcode?
        Thanks for your help.
      • Veti
        Veti last edited by
        the default setting from the configurator should produce the required config.
        did you make any changes to that?
        check the wiring diagram.
        https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
        the fan headers have a v_fan pin which is the red wire and the other is the black wire.
        gdefranc 1 Reply Last reply Reply Quote 0
          https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
          Fan0 is typically the part cooling fan and Fan1 is the hotend heatsink fan.
          • gdefranc
            gdefranc @Veti last edited by
            @Veti
            I connected them here,
            they turn on at start-up that of the hotend turns on when it reaches temperature.
            But I can't control and / or turn them off.
            • Veti
              Veti last edited by
              post your config.g
              • gdefranc
                @Veti
                Eccoli.
                config.g
                config-override.g
                • Veti
                  Veti last edited by
                  M106 P0 S0 H0 T45 ; set fan 0 value. Thermostatic control is turned on
                  you configured both fans to be non controllable.
                  change first one to
                  M106 P0 S0 H-1
                  • gdefranc
                    @Veti
                    Thanks a lots
                    the new configuration will be like this then
                    M950 F0 C "fan0" Q500; create fan 0 on pin fan0 and set its frequency
                    M106 P0 S0 H-1 T45; set fan 0 value. Thermostatic control is turned on
                    M950 F1 C "fan1" Q500; create fan 1 on pin fan1 and set its frequency
                    M106 P1 S1 H-1 T45; set fan 1 value. Thermostatic control is turned on
                    Also I wanted to ask if there is any other optimization I can do for the speech fans.
                    I was advised to keep the hotend fan off when printing both PLA and PETG. How do you manage them?
                    Veti 1 Reply Last reply Reply Quote 0
                    • Veti
                      Veti @gdefranc last edited by
                      @gdefranc said in 24v fan connection on Duet 2 wifi:
                      i dont think you used the right words here. do you mean noise?
                      PLA wants cooling.
                      pets wants a little bit of cooling
                      That is managed in the slicer fan setting
                      • gdefranc
                        @Veti said in 24v fan connection on Duet 2 wifi:
                        PLA wants cooling.
                        Sorry.
                        Also I wanted to ask if there other optimization I can do for the fans
                        • Veti
                          @gdefranc
                          what do you mean by optimizations?
