    help setting z axis 4 motors and endstop and one probe
    Using Duet Controllers
    263
    • OsherHachm
      OsherHachm last edited by
      hi,
      I have the Duet 2 wifi with the Duex 5.
      the RRF 3.2,
      Cartesian printer type,
      I have try so hard to make it woke but now I'm stock and the Z axis is move only 5mm and stop, the error that it wrote is "G28 field to enable endstop.
      I did't start to config the z probe.
      I have 4 z motors, 2 x motors ,1 y motor.
      NC endstop switches.
      ZRR meaning Z axis Rear Right.
      thank you for the help.```
      code_text
      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sun Jan 17 2021 14:40:54 GMT+0200 (Israel Standard Time)
      M550 P"My Printer"                                 ; set printer name
      M551 P"Osh753951"                                  ; set password
      M586 P1 S1                                         ; enable FTP
      M586 P2 S1                                         ; enable Telnet
      M569 P0 S1                                         ; physical drive 0 goes forwards Y
      M569 P1 S1                                         ; physical drive 1 goes forwards XL
      M569 P2 S1                                         ; physical drive 2 goes forwards XR
      M569 P3 S1                                         ; physical drive 3 goes forwards E0
      M569 P4 S1                                         ; physical drive 4 goes forwards
      M569 P5 S1                                         ; physical drive 5 goes forwards ZRR
      M569 P6 S1                                         ; physical drive 6 goes forwards ZRL
      M569 P7 S1                                         ; physical drive 7 goes forwards ZFR
      M569 P8 S1                                         ; physical drive 8 goes forwards ZFL
      M569 P9 S1                                         ; physical drive 9 goes forwards
      M584 X1:2 Y0 Z5:6:7:8   E3                                                   ; set drive mapping ; Driver 1,2 For X, 0 for Y, Z=5,6,7,8 , Extruder 3
      M350 X16:16 Y16 Z16:16:16:16 E16 I1                                             ; configure microstepping with interpolation
      M92 X80.00:80.00 Y80.00 Z1600.00:1600.00:1600.00:1600.00 E420.00                  ; set steps per mm
      M566 X900.00:900.00 Y900.00 Z600.00:600.00:600.00:600.00 E120.00               ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00:6000.00 Y6000.00 Z180.00:180.00:180.00:180.00 E1200.00     ; set maximum speeds (mm/min)
      M201 X500.00:500.00 Y500.00 Z20.00:20.00:20.00:20.00 E250.00               ; set accelerations (mm/s^2)
      M906 X800:800 Y800 Z900:900:900:900 E800                                      ; set motor currents (mA)
      M84 S0        ; Disable motor idle current reduction
      M208 X1000 Y1000 Z990 S0                           ; set axis maxima
      M574 X2 S1 P"!zstop"                               ; configure active-high endstop for high end on X via pin !zstop
      M574 Y2 S1 P"!xstop"                               ; configure active-high endstop for high end on y via pin !xstop
      M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e4stop+!duex.e5stop"         ; configure active-high endstop for high end on z via pin !duex.e2stop
      ;M558 P1 C"zprobe.in" H5 F120 T6000                 ; set Z probe type to unmodulated and the dive height + speeds
      ;G31 P500 X0 Y0 Z5                                  ; set Z probe trigger value, offset and trigger height
      ;M557 X5:995 Y5:995 S20                             ; define mesh grid
      M308 S0 P"spi.cs1" Y"rtd-max31865"                 ; configure sensor 0 as thermocouple via CS pin spi.cs1
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"spi.cs2" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs2
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                       ; set temperature limit for heater 2 to 280C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H1:2 T45                                ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1:2 T45                                ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"e1..h1" D1 H1 F0                         ; define tool 0
      M563 P1 S"e0..h2" D0 H2 F0                         ; define tool 1
      G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      M911 S15 R20 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      code_text
      ; called to home all axes
      G91                       ; relative positioning
      G1 H2 Z5 F6000            ; lift Z relative to current position
      G1 H1 X-1005 Y-1005 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000         ; go back a few mm
      G1 H1 X-1005 Y-1005 F360  ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z990 F360           ; move Z up stopping at the endstop
      G90                       ; absolute positioning
      G92 Z990                  ; set Z position to axis maximum (you may want to adjust this)
      ;G91                      ; relative positioning
      ;G1 Z5 F100               ; lift Z relative to current position
      ;G90                      ; absolute positioning
      • fcwilt
        fcwilt last edited by
        Your M574s specify the end stop sensors are at the high end (max end of axis)
        Yet in your home file you are moving X and Y toward the low end (min end of axis)
        Is that actually working for you?
        Are you Z axis end stop sensors really positioned at the high end (max end of axis)?
        Thanks.
        • OsherHachm
          how do I fix this ?
          yes the end stop for the Z axis is at the high positioned.
          I try to change the config file to and it stop the error but it stop all the motors when the !duex.e2stop is triggered ```
          M574 Z2 S1 P"!duex.e2stop+!duex.e3stop"         ; configure active-high endstop for high end on z via pin !duex.e2stop+!duex.e4stop+!duex.e5stop
          • fcwilt
            fcwilt last edited by fcwilt
            You did not say if X and Y homing was working as you have it now.
            I will assume it isn't until you say otherwise.
            In your homing file change X-1005 to X1005 and Y-1005 to Y1005 in the two G1 commands.
            As to the position of your Z end stops you said "is at the high positioned" - I don't know what that means.
            So let me ask another way. If you move the bed on the Z axis toward the extruder assembly are you moving towards Z min and the Z end stops?
            And why did you remove those two Z end stop entries from the M574?
            • OsherHachm
              @fcwilt said in help setting z axis 4 motors and endstop and one probe:
              yes 🙂
              because it write my the erorr "G28 field to enable endstop."
              fcwilt 1 Reply Last reply Reply Quote 0
              • fcwilt
                fcwilt @OsherHachm last edited by fcwilt
                @OsherHachm said in help setting z axis 4 motors and endstop and one probe:
                yes 🙂
                Then in your config file you need to...
                • change M574 Z2 to M547 Z1
                Then in your homing file you need to...
                • change the G1 H1 Z990 F360 to G1 H1 Z-990 F360
                • remove or comment out the G92 Z990
                Well if you have four physical Z end stop sensors you are going to need four end stop inputs referenced in the M574 for Z.
                I don't know why you are getting the error but restore all four pin name references for now.
                Onec you make the change reboot and try to home the printer.
                • Veti
                  Veti last edited by
                  run M92 P"config.g" to check for errors in your config
                  OsherHachm 1 Reply Last reply Reply Quote 0
                    Please also share the results of M122.
                    How many Z endstops do you physically have? Are you intending to use multiple endstops to level the 4 motors?
                    • OsherHachm
                      Ok after reading a lot of articles I still did not succeeded to operate the end stop triggers each motor individual but I think that's not necessary because I'm leveling the nuzzle from the low end ( z min is close to the bed) so I decided for every axis will be one end stop.
                      The new problem I'm having is when I homing the X axis it's run slowly and the Z axis as well at the same time(hapooening only for the X axis).
                      Configuration file
                      ```    ; Configuration file for Duet WiFi (firmware version 3)
                      M569 P1 S0                                         ; physical drive 1 goes forwards XL
                      M569 P5 S0                                         ; physical drive 5 goes forwards ZRR
                      M569 P6 S0                                         ; physical drive 6 goes forwards ZRL
                      M569 P7 S0                                         ; physical drive 7 goes forwards ZFR
                      M569 P8 S0                                         ; physical drive 8 goes forwards ZFL
                      M584 X1:2 Y0 Z5:6:7:8 E3                           ; set drive mapping X=1,2, Y=0, Z=5,6,7,8, E0=3
                      M669 K0                                            ;select Cartesian printer mode
                      M566 X900.00:900.00 Y900.00 Z60.00:60.00:60.00:60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
                      M208 X1000 Y1000 Z970 S0                                                ; set axis maxima
                      M574 X1 S1 P"!zstop"                                                    ; configure active-low endstop for low end on X via pin !zstop
                      M574 Y1 S1 P"!xstop"                                                    ; configure active-low endstop for low end on Y via pin !xstop
                      M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e4stop+!duex.e5stop"       ; configure active-low endstop for high end on Z via pin
                      M667 X1000:1000:0:0 Y0:1000:0:1000 S2              ;coordinates of the leadscrews 5=(1000,0) 6=(1000,1000) 7=(0,0) 8=(0,1000)
                      ; bed.g
                      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sun Jan 24 2021 06:53:58 GMT+0200 (Israel Standard Time)
                      G29  ; probe the bed and enable compensation
                      G28                              ; home
                      M401                             ; deploy Z probe (don't know if it's good for the IR probe)
                      G30 P0 X1000 Y0 Z-99999          ; probe near a leadscrew
                      G30 P1 X1000 Y1000 Z-99999       ; probe near a leadscrew
                      G30 P2 X0 Y0 Z-99999             ; probe near a leadscrew
                      G30 P3 X0 Y1000 Z-99999 S4       ; probe near a leadscrew and calibrate 4 motors
                      M402          ; don't know if it's good for the IR probe
                      code_text
                      ; homeall.g
                      code_text
                      ; homex.g
                      ; called to home the X axis
                      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sun Jan 17 2021 14:40:55 GMT+0200 (Israel Standard Time)
                      G1 H1 X-1005 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 H2 X5 F6000     ; go back a few mm
                      G1 H1 X-1005 F360  ; move slowly to X axis endstop once more (second pass)
                      G1 H2 Z-5 F6000    ; lower Z again
                      code_text
                      ; called to home the Z axis
                      G1 H1 Z990 F1800 ; move Z up until the endstop is triggered
                      • OsherHachm
                        I forgat to mention the error
                        "G28 Z
                        Error: Failed to enable endstops"
                        @Phaedrux said in help setting z axis 4 motors and endstop and one probe:
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later + DueX5
                        Board ID: 0JD0M-9P61A-J8PS8-6J1F4-3S86Q-KUV2T
                        Used output buffers: 3 of 24 (19 max)
                        Static ram: 23460
                        Dynamic ram: 73992 of which 88 recycled
                        Never used RAM 14540, free system stack 118 words
                        Tasks: NETWORK(ready,185) HEAT(blocked,317) DUEX(blocked,35) MAIN(running,463) IDLE(ready,19)
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 00:12:49 ago, cause: software
                        Last software reset at 2021-01-24 18:44, reason: User, GCodes spinning, available RAM 14604, slot 2
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU temperature: min 18.8, current 19.7, max 20.0
                        Supply voltage: min 22.8, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: position 200, standstill, SG min/max 9/82
                        Driver 1: position 0, standstill, SG min/max 13/80
                        Driver 2: position -4004, standstill, SG min/max 0/66
                        Driver 5: position 0, standstill, SG min/max 69/213
                        Driver 6: position 0, standstill, SG min/max 56/195
                        Driver 7: position 0, standstill, SG min/max 39/200
                        Driver 8: position 0, standstill, SG min/max 29/192
                        Driver 9: position 0, standstill, SG min/max not available
                        Driver 10: position 0
                        Driver 11: position 0
                        Date/time: 2021-01-24 18:57:17
                        Cache data hit count 954438988
                        Slowest loop: 9.48ms; fastest: 0.18ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 1.4ms, write time 0.0ms, max retries 0
                        DMs created 83, maxWait 617139ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 16, completed moves 16, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 80.72ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        • WiFi -
                          Network state is active
                          WiFi firmware version 1.23
                          WiFi MAC address 48:3f:da:72:9b:29
                          WiFi Vcc 3.44, reset reason Power up
                          WiFi flash size 4194304, free heap 21656
                          WiFi IP address 10.0.0.5
                          WiFi signal strength -78dBm, mode none, reconnections 0, sleep mode modem
                          Clock register ffffffff
                          Socket states: 4 2 0 0 0 0 0 0
                          === DueX ===
                          Read count 1, 0.08 reads/min
                        leveling the nuzzle to the bed I using the IR sensor, this is the one I bought OrmerodSensor V1.2 IR Height Sensor
                        • OsherHachm
                          OsherHachm @Veti last edited by
                          @Veti
                          M92 P"config.g"
                          Steps/mm: X: 80.000, Y: 80.000, Z: 1600.000, E: 420.000
                          • OsherHachm
                            maybe I need to put the leveling in the macros folder ?
                            • Veti
                              Veti last edited by Veti
                              according to the configurator the endstops are called like
                              exp.e3stop
                              your steps configuration is incorrect.
                              only on E are : notations allowed. remove them for the commands.
                              • fcwilt
                                With v3 firmware homing with multiple Z steppers each with their own end stop sensor couldn't be much easier.
                                This are just a few settings you have to get right and it's easy to test step by step to get it working.
                                The nice thing about that setup is, with a bit of care, you can quickly get the bed very close to level before utilizing the slower process of Automatic Bed Leveling (ABL) to fine tune the result.
                                Hope you change you mind.
                                  should be
                                  M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
                                  M92 X80.00 Y80.00 Z1600.00 E420.00         ; set steps per mm
                                  M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
                                  M203 X6000.00 Y6000.00 Z180.00 E1200.00   ; set maximum speeds (mm/min)
                                  M201 X500.00 Y500.00 Z20.00 E250.00              ; set accelerations (mm/s^2)
                                  M906 X800 Y800 Z900 E800                               ; set motor currents (mA)
                                  Only the extruders need to be independently defined for each motor because each extruder is an independent axis. Multiple motors on an axis only get the values per axis.
                                  I'm not really sure what you mean by this.
                                  I'm not sure what you mean by this either. Your endstops are configured at the high end of the Z axis. Are they actually located at the low end?
                                  If you're using the probe to level, does your bed.g work correctly?
                                  Also, if it's an IR probe, you don't need M401 and M402 in your bed.g
