    updating duet 2 wifi and installing firmware
    Using Duet Controllers
    775
    • popayaundefined
      popaya
      hello i´m new to this and have a lot of questions concerning duet 2 wifi and the new duet3 the more i try to find out the more i get lost ...is there anyone who can guide me tru this?
      • Vetiundefined
        Veti
        there is a extensive guide in the documentation
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        • popayaundefined
          popaya
          thankyou for your fast answer ! i tried to update my duet2 wifi v1.03 now i get always error messeges with yat or cant even start yat
          what i´m doing wrong?
          • popayaundefined
            popaya
            now after opening yat i see this
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05<LF>ok<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi module is idle<LF>WiFi reported[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
              Change your line ending settings in YAT to get the proper formatting and full output. But it looks like you've successfully updated to 3.2
              If you add your wifi SSID and password now and you have the DWC files in the /www folder you should be able to access the web interface.
              https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
              popayaundefined 1 Reply Last reply Reply Quote 0
              • popayaundefined
                popaya @Phaedrux
                @Phaedrux thanks for your help.
                i wil try this now...
                stil i dont know where to go from there... i have 5 ...acctualy a lot more motors ..with optical encoders on their back is it possible to make them work and to use the encoder signal or do i have to use external drivers to have a closed loop system.
                at the momnt i have the duet 2 wifi but i would buy also the duet 3 if it would ´suit better to my needs .
                  The duet itself doesn't directly support closed loop function, though there is a expansion board for the duet 3 to allow that under development.
                  So maybe get started without worrying about closed loop and evaluate later.
                  • popayaundefined
                    popaya @Phaedrux
                    @Phaedrux thank´s ! i try to get this thig running without worrying about closed loop ....was just a question that was not clear to me.
                    thank´s for your help.
