    Duet2 wifi Not connecting
    Duet Web Control
    3.7k
      Were you able to follow the wifi firmware update link I posted above? You can confirm the wifi server firmware version with M122. The wifi section is at the end.
      • Tisum1979undefined
        Tisum1979
        This is what it shows when I ran M122- - WiFi -<LF>
        Network state is running<LF>
        WiFi module is idle<LF>
        Failed messages: pending 0, notready 0, noresp 0<LF>
        WiFi firmware version 1.20<LF>
        WiFi MAC address 98:f4:ab:cf:be:21<LF>
        WiFi Vcc 3.33, reset reason Turned on by main processor<LF>
        WiFi flash size 4194304, free heap 19576<LF>
        Socket states: 0 0 0 0 0 0 0 0<LF>
        ok<LF>
          @Tisum1979 said in Duet2 wifi Not connecting:
          Still on 1.20.
          Please follow this link an update your wifi server firmware.
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware
          The correct version for RRF 2.05 is wifi server 1.23
            Tisum1979
            Ran M587 and this is what it shows- Remembered networks:<LF>
            MySpectrumWiFiF8-2G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>
            ok<LF>
              Did you look at the link?
              Updating WiFi firmware
              Upload the new DuetWiFiServer.bin file to the /sys folder on the on-board SD card, either via the Settings page of DuetWebControl (if WiFi is working), or by temporarily moving the on-board SD card to a PC. If you copy it directly to the SD card on a PC, you must remove the version number from the filename so that its name on the SD card is exactly DuetWiFiServer.bin. If you upload it through the Settings page of DuetWebControl, the renaming will be done automatically.
              Send command M997 S1 to install the new firmware. Preferably, send this command from Pronterface or PanelDue, because then the update status will be reported.
              If you sent the M997 S1 command via the web interface, it will lose the connection and you should allow a minute or so for the firmware installation to complete before you press the Connect button.
                Tisum1979
                ok, so I did what you said and took the 1.23 off the Duetwifiserver.bin as you said. I loaded it to my SD card from usb way. I uploaded it on yate with the command 997 S1 and this is the response given- - WiFi -<LF>
                Network state is disabled<LF>
                WiFi module is disabled<LF>
                ok<LF>
                  Now send M552 S1 to re-enable the wifi module and then M122 again to check it.
                  When you sent M997 S1 what did it actually say? The text you've posted is the results of M122.
                    Tisum1979
                    I can not connect to my DWCB to be able to load any thing that way. I still get the blue blinking light indicating it is trying to connect to the internet.
                      Tisum1979
                      This is what I got- - WiFi -<LF>
                      Network state is changing mode<LF>
                      WiFi module is trying to connect<LF>
                      WiFi firmware version 1.23<LF>
                      WiFi flash size 4194304, free heap 27864<LF>
                      ok<LF>
                      WiFi reported error: Failed while trying to connect to MySpectrumWiFiF8-2G<LF>
                        Remove the SD card from the Duet and put it in your PC.
                        Download this file: https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetWiFiServer.bin
                        and put it in the /sys folder. Overwrite any existing file of the same name.
                        Now put the SD card back in the Duet and connect via USB terminal.
                        Send M997 S1 to flash the wifi firmware.
                          Phaedrux Moderator @Tisum1979
                          Ok, at least we got that flashed now.
                          Does your wifi password include any special characters or capital letters?
                          It might be a good idea to set up some macros to make wifi trouble shooting a bit easier.
                          https://github.com/Duet3D/RRF-machine-config-files/blob/master/DBotCoreXY/x0r-wifi-RRF3/macros/Diagnostics/WIFI-Forget Networks
                          https://github.com/Duet3D/RRF-machine-config-files/blob/master/DBotCoreXY/x0r-wifi-RRF3/macros/Diagnostics/WIFI-Add SSID
                          https://github.com/Duet3D/RRF-machine-config-files/blob/master/DBotCoreXY/x0r-wifi-RRF3/macros/Diagnostics/WIFI-Reset Module
                          https://github.com/Duet3D/RRF-machine-config-files/blob/master/DBotCoreXY/x0r-wifi-RRF3/macros/Diagnostics/WIFI-AP-MODE
                          You can download those and use a text editor to edit them to match your own SSID and password.
                          Then put them on the SD card in the /macros folder.
                          Then you can execute them with M98 P"MACRONAME"
                          or you can just use the text of them as a guide on what to type in the USB terminal. The nice thing about the macro for the wifi SSID and password is that it avoids the problem of the USB terminal altering the password being sent.
                            Tisum1979
                            This is what was said when I sent M997 S1- M997 S1<LF>
                            M997: File DuetWiFiServer.bin not found<LF>
                            ok<LF>
                              Tisum1979
                              I feel like I am banging my head against a wall. I went to the link you sent me and downloaded then transfered over to the sd card sys. file but it didn't ask if I wanted to replace existing files.
                                It must have found it at some point if M122 says you're using version 1.23 now.
                                  Tisum1979
                                  I just typed in M122 and it shows the version is 1.23
                                    Now that you have the wifi server updated, try sending these commands over USB terminal:
                                    M552 S0 ; Disable network module
                                    M588 S"*" ; Clear all saved wifi networks
                                    M587 S"NETWORKNAME" P"PASSWORD" ; add your network
                                    M552 S1 ; enable wifi module
                                      Tisum1979
                                      Keep in mind I am green at this so I don't understand some of the terms used or if I am downloading the correct things
                                        No problem. If there's anything you're unsure of, just ask for clarification.
                                          Tisum1979
                                          My SSID had upper and lower case letters is that an issue
                                            Tisum1979
                                            Should I use all upper or lower case letters for my password
