Duet2 wifi Not connecting
Can I upgrade firmware from 2.05.1 / wifi firmware version 1.23 if I can not get onto my WCB?
ok so I created a access point which isn't connected to the internet however I typed in my IP address and the control board popped up and the blue light is on to my wifi but I can not get my WCB to connect
@Tisum1979 said in Duet2 wifi Not connecting:
Where did you get that ip address? Are you sure it's correct?
You mean on your router, or with the Duet itself as an access point?
Yes you can, but I would suggest getting connected first and doing it from the DWC if at all possible.
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
