    SOLVED Changing ports
    Duet Web Control
    100
    • JBisc
      JBisc last edited by JBisc
      @chrishamm recommended me for another problem to change my DWC port.
      I changed
      /opt/dsf/conf/http.json
      into
        "Kestrel": {
          "Endpoints": {
            "Http": {
              "Url": "http://*:1000"
      but after an restart, even if I was able to connect to //my:1000 and DWC was responding, the DWC is not able to connect to the Duetboard.
      Is there a second config file which I have to change?
      Setup:
      SW 3.2 Duet3
      not standalone mode
      My Setup: Duet 3 MB6HC Main Board with attached RPI
      • chrishamm
        chrishamm administrators last edited by chrishamm
        That's all good but don't forget to restart the web server when you're done:
        sudo systemctl restart duetwebserver
        I just checked this and it's working as expected.
        PS: If it didn't work the first time, make sure you're connecting over HTTP and not over HTTPS. Some browsers change the protocol in the URL from HTTP to HTTPS when the first connection attempt failed.
        Duet software engineer
        • JBisc
          @chrishamm Ok? That's interesting. I used http://192.168.1.7:1000/ and checked that it was http and it did not work.
          Changed my config back by removing the port. Restarted Server -> worked again.
          chrishamm 1 Reply Last reply Reply Quote 0
          • chrishamm
            chrishamm administrators @JBisc last edited by chrishamm
            @JBisc Did you try another port? It's definitely working on my setup with 3.2 and I can confirm the DWC WebSocket+REST requests go to port 1000 too.
            Edit: Interesting, it stopped working after a reboot. Can you addM586 C"*" to your config file and check if that helps? It might be a CORS problem.
            JBisc 1 Reply Last reply Reply Quote 0
            • T3P3Tony
              Duet Hardware Designer
              www.duet3d.com
              • T3P3Tony
                T3P3Tony administrators @T3P3Tony last edited by T3P3Tony
                ☝ for Christian who is having issues with posting images
                www.duet3d.com
                • JBisc
                  JBisc @chrishamm last edited by
                  As so often: @chrishamm has the right answer!
                  M586 C"*"
                  helped! Thanks!
                  • chrishamm
                    @JBisc Thanks for confirming, I'll work out a fix for the next DWS version.
                    PS: I've got a fix ready, it will be part of the next software release.
