Gcode postproces with fusion 360
  • What postprocessor do you guys use for a CNC with a duet 2 wifi?
    I tried multiple ones like:
    Workbee
    RS-274
    Mach2
    Mach3
    They all don't work with the duet 2. Like when I send it to the machine it just goes to the home position.
    I hope someone can help me with it.
  • Hi,
    Not sure if this will help you. Im running a Duet 3 6HC with a raspberry pi3b+. My cnc is an Openbuilds Lead 1010 with high z mode.
    I use the Ooznest post processor for fusion-360 as the Workbee lead screw cnc is practically the same. Ive loaded the post processor into my Fusion 360 Library> Assets> CAMPost.
    Fusion-v1.0.1
    https://ooznest.co.uk/wp-content/uploads/2019/02/Fusion-v1.0.1.zip
    Im still pretty new to cnc, Duet controllers and RepRap firmware so i cant say how perfect it runs but it works well on the jobs ive done already.
  • Hello,
    I use the Reprap post processor. its an option from fusion 360. this allows me to use the M3 and M7 for spindle and mist cooling.
    Good luck.
