    duet 2 rrf 3.2 300x300mm heatbed pid tune failed
    rrf3 duet ethernet heat bed pid autotune heating fault
    • Dentokke
      Dentokke last edited by
      hello,
      i'm totally new here so sorry if this doesn't belong here.
      today my power supply arrived 12v 600w 0-50A, only for my heatbed it's an aluminum plate from ratrig 3003004mm
      i use an kapton heatpad with the same dimensions on 12v i have placed a thermistor (T100000 B4138) on it and covered the whole thing with insulation to prevent heat loss from the bottom.
      now i started the pid tune of my bed and after 3 hours it gave me this error:
      21-1-2021 21:56:58 Warning: heater behaviour was not consistent during tuning
      Warning: Auto tune of heater 0 failed due to bad curve fit (R=0.036, 1/C=-0.0069:-0.0069, D=0.5)
      21-1-2021 19:42:21 Auto tune starting phase 3, fan off
      21-1-2021 19:22:44 Auto tune starting phase 2, heater settling
      21-1-2021 19:22:44 Auto tune starting phase 1, heater on
      21-1-2021 19:22:39 M303 H0 S50
      Auto tuning heater 0 using target temperature 50.0°C and PWM 1.00 - do not leave printer unattended
      what can be the issue? the power supply has more then enough watts could it be that i use an mosfet?
        Can you post your config.g?
        Can you send M122 and post the results?
        Can you send M98 P"config.g" and post the results?
        Perhaps photos of your bed and wiring?
        What is the wattage of the bed heater?
        3 hours isn't unheard of for a bed heater, but the bad curve fit is obviously a problem.
        The thermistor might work better embedded in the aluminum plate rather than directly connected to the heater. The algorithm seems the temps increase quickly, but the large aluminum heatsink is quickly carrying away the heat. You could in fact use two thermistors. One embedded for the temperature control, and one directly attached to the heater for a temperature exceed monitor.
        • Dentokke
          Config.g
          M550 P"Den Tokke" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z1600.00 E418.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X290 Y294 Z560 S0 ; set axis maxima
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 R1.736 C235.4 D4.24 S1.00 V12.0 ; PID waarden hotend
          M122
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later
          Board ID: 0JD0M-9P6M2-NW4SS-6JKD6-3S86P-TBZHL
          Used output buffers: 3 of 24 (17 max)
          Static ram: 23460
          Dynamic ram: 68608 of which 48 recycled
          Never used RAM 19964, free system stack 191 words
          Tasks: NETWORK(ready,160) HEAT(blocked,71) MAIN(running,456) IDLE(ready,19)
          Owned mutexes:
          Last reset 03:43:49 ago, cause: power up
          Last software reset at 2021-01-16 17:02, reason: User, GCodes spinning, available RAM 19816, slot 0
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 27.1, current 35.1, max 36.2
          Supply voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-01-21 22:29:26
          Slowest loop: 16.13ms; fastest: 0.20ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.9ms, write time 6.4ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 32.57ms; fastest: 0.02ms
          Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          **M98 P"config.g" **
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 433C
          21-1-2021 22:29:28 m122
          for the wiring the kapton heatmat was pre made, only extended the wires with 14AWG wires.
