Errore on Version 1.19RC1/ DWC
connect but error after 10second !!!
Hi Davide
Firmware Version: 1.19RC1 (2017-08-03)
WiFi Server Version: 1.19beta10
Web Interface Version: 1.17+2Maximum number of AJAX retries: 10
Why is the RC1? not problems on beta 11
Giorgio
Strange, the network interface hasn't changed between beta 11 and RC1. If it's repeatable, or triggered by some particular action, please share a Wireshark trace,
Are you able to reconnect, or do you need to stop/restart the wifi module (if you are using a Duet WiFi) or the whole Duet before you can?
Wireshark ? Sorry … done explications
( I use OSX ) Yes is repeatable... stop/restart the connections work for 10/15 second ....???https://www.wireshark.org/
Is this ?
see https://www.wireshark.org/#download available for mac as well as other platforms
Thanks
Wireshark trace BLUTYPPA
https://www.dropbox.com/s/ktiq636d4xsmxno/BluTyppa.pcapng.gz?dl=0
i hope is this
Thanks DCd2 David
Hi David for sending one video is possible email ? thank ( now on YouTube )
I send one gcode to printing … after the WDC NOT REPOND TO WEB
I use Crome last releaseConfig,g
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Wed Jul 05 2017 17:26:08 GMT+0200 (CEST); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like Marlin;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R222.5 L394 B150 H480 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
M208 Z-0.1 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Define active high microswitches
M558 P1 X0 Y0 Z0 H15 F120 T3000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P500 X10.80 Y-5.2 Z2.230 ; Set Z probe trigger value, offset and trigger height
M557 R110 S20 ; Define mesh grid; Drives
M350 X32 Y32 Z32 E32 I1 ; Configure microstepping with interpolation
M92 X320 Y320 Z320 E809 ; Set steps per mm
M566 X1200 Y1200 Z2300 E1200 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X1300 Y1300 Z1300 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S285 ; Set maximum heater temperature to 285C
M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PBluTyppa ; Set machine name
M552 S1 ; Enable network
M551 PTyppa
; Access point is configured manually via M587 by the user
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Enable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Custom settings are not configured
M579 X1.0083 Y1.01153 ;Scale Cartesian axes 100/Valore trovato
M572 D0 S0.1 ;pressure advance coefficientM501 ;Read new
Filament Sensor
M581 E1 S0 T2 ; Trigger 2 rised if filament is missing. Switch on E1 connect; Miscellaneous
T0 ; Select first toolconfig-override.g
; Delta parameters
M665 L402.928 R226.379 H468.561 B150.0 X-0.472 Y-0.209 Z0.000
M666 X0.703 Y-0.562 Z-0.141 A0.00 B0.00
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 B1
M307 H1 A195.3 C102.1 D5.2 S1.00 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 B0
; Z probe parameters
G31 T1 P500 X10.8 Y-5.2 Z2.23
G31 T3 P500 X0.0 Y0.0 Z0.70
G31 T4 P500 X0.0 Y0.0 Z0.00
Likely a mistake? With beta 11 I do not succeed … then with pressure Advance does a strange thing ... as if it were going to small shots....
Can you check my config?
Thanks David DC42
