    G29 doesnt use the M557
    • idaho creator
      idaho creator last edited by
      When I try to do mesh bed leveling I home my printer It successfully does that then when I go to use G29 the printer goes to x100 y-60 and deploys probe and tries to probe in thin air.
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 24 2021 21:50:34 GMT-0700 (Mountain Standard Time)
      M550 P"badass printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.0 S0 ; physical drive 0.0 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes backwards
      M569 P0.4 S1 ; physical drive 0.4 goes backwards
      M584 X0.1 Y0.2 Z0.0 E0.3:0.4 ; set drive mapping
      M350 X256 Y256 Z256 E16:16 I0 ; configure microstepping without interpolation
      M92 X2048.00 Y2048.00 Z13120.00 E412.1:412.1 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E500:500 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-20 Y-40 Z0 S1 ; set axis minima
      M208 X330 Y330 Z450 S0 ; set axis maxima
      M574 X1 S1 P"io6.in" ; configure active-high endstop for low end on X via pin !io6.in
      M574 Y1 S1 P"io5.in" ; configure active-high endstop for low end on Y via pin !io5.in
      M950 S0 C"io1.out" ; create servo pin 0 for BLTouch
      M558 P9 C"^io1.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X150 Y150 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X30:300 Y50:300 S40 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
      M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
      M563 P1 D1 H1 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      ; Custom settings
      M575 P1 S1 B57600
      M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        Phaedrux Moderator @idaho creator last edited by
        @idaho-creator said in G29 doesnt use the M557:
        Your probe is probably not 150mm away from the nozzle in X and Y I'm guessing. You'll have to measure the actual distance.
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
        • idaho creator
          Measured it to be x145 and y160. but when I enter g29 it goes to x120 Y-60 and not X50 Y50
          • idaho creator
            Never mind I miss read your post I did not see the offset, Ill fix that
