    Duet 2 Wifi and Airwolf 3D HD - Fan not coming on.
    Using Duet Controllers
    • tonnic
      tonnic last edited by
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
      Duet WiFi Server Version: 1.25
      I have the fan plugged into FAN1 pin as the documentation I read said that it was the safest as FAN1 comes on by default on power up.
      Here is what I have for my fans
      M950 F0 C"fan1" Q500                               ; create fan 0 on pin fan1 and set its frequency
      M106 P0 T45 H1 S1								; set fan 0 value. Thermostatic control is turned on
      The fan does turn on when I'm not using sliced gcode... I turned my hotend to 60 and it turned on around the 45 mark.
      When I use Cura to slice my gcode, it is set to not use the fan for the first 3 layers and then turn on at 100%.
      It isn't turning my fan on... Can anyone assist?
        Check your cura settings for what fan it's trying to target.
        Can you share a sliced gcode file from cura?
        Also, post your full config.g
