    1xd can transmission capacity
    • huai3895undefined
      huai3895
      Like that bro ,i using 1XD to build XY , find a similar problem:
      https://forum.duet3d.com/topic/17780/clearpath-servos-with-1xd-expansion/74
      I am 100% sure that servos are not loosing position too.
      I can almost confirm the problem : some movement commands are being lost in transmission from the main board to the expansion board.
      This is my test :
      try use 2.7-50 in m569 no change ,no help
      try use 80-600 in m92 no change ,no help
      try use Slower speed more slwoer more normal
      try different 3d model more simpely more normal
      try to reduce face of model less mesh more normal
      This my analysis:
      if problem is by m569 or m92, it shoud affected only by move speed,and the less mesh model or simpely model should not return to normal,but it does normal
      if problem is commands lost between can, less speed/simpely model/less mesh model can reduce CAN communication data in same time , i think it makes sences
      more date in same time can make CAN lost commands ,so i think CAN transmission performance is not enough.
      can it be fix by firmware update?
      it is a very serious problems cause i have to delivery to customers soon, if cant fix that,i will lose hundreds of thousands of dollars😧 😧 😧
      • Vetiundefined
        Veti
        did you install the 3.3 beta release? lots of 1xd fixes there.
        https://forum.duet3d.com/topic/20991/early-rrf-3-3beta-files-available
        huai3895undefined 1 Reply Last reply Reply Quote 1
        • huai3895undefined
          huai3895
          OK,I will try this
          • huai3895undefined
            huai3895 @Veti
            @Veti oh!!!thank to god,thank to duet,thank to dc42,This is my life-saving straw!!!
