UNSOLVED BLTouch and Duet 2 wifi + Duex 5
I have bought an original BLTouch from "antclabs", I've checked my wiring twice but it still flashing red when I power it up.
When the machine is powered, the tip of the BLTouch deploys touches the glace bed and retracts. It does it twice but then comes back up and doesn't stop flashing red. When you look on the DWC it gives you "Z probe: 1000".
I've also tried different codes like M401 or M280 P0 S10 to test it but nothing happens.
The BLTouch is connected to the PWM1 on the duex board and the two other wire are connected to the duet 2 on the "z probe in" PIN and the "GND" PIN.The machine is a custom made printer:
- Board : Duet 2 wifi + Duex 5
- Firmware : 3.1.1
- BLTouch : 3.1 original
- That's my config.g :
code_text ; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Nov 14 2020 12:54:59 GMT+0100 (Central European Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"The Dream Machine" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M569 P5 S0 ; physical drive 5 goes backwards M569 P6 S1 ; physical drive 6 goes backwards M569 P7 S1 ; physical drive 7 goes forwards M569 P8 S0 M569 P9 S0 M584 X0 Y1:5:6:7 Z8:9 E3:4 ; set drive mapping M350 X16 Y16 Z16 E16:16:16:16:16 I1 ; configure microstepping with interpolation M92 X160.00 Y80.00 Z800.00 E420.00:420.00:420.00:420.00:420.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z1200 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1000 Y1200 Z850 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ; Z-Probe M307 H3 A-1 C-1 D-1 M558 P9 C"^zprobe.in" H5 F120 T7200 G31 P500 X35 Y4 Z2.1 M950 S0 C"duex.pwm1" ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S75 M570 H0 P150 T15 ; set temperature limit for heater 0 to 75C M308 S1 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 M570 H1 P150 T15 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off ; Tools M563 P0 S"Super Volcano" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Volcano" D1 H2 F1 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue
I'm unable to see what wrong, and I've been pulling my hair to try and make it work but I haven't had any success yet. Could they be a problem with my codes?
Cheers, George
The file you posted says you are using v3 firmware.
The syntax used by the commands configuring your BLTouch are for v2.
So please verify what firmware you are using.
@George said in BLTouch and Duet 2 wifi + Duex 5:
M307 H3 A-1 C-1 D-1
This isn't used in RRF3 anymore. Remove it.
Confirm your firmware version with M115.
Are you actually on 3.1.1?Firmware 3.2 is out now as well so please update.
You can upload this zip file to the system tab.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
If after all of that you still can't get the pin to deploy and retract with M401 and M402 check the wire going to duex.PWM1 for continuity. Maybe a bad crimp.
Otherwise try PWM5 instead.
The pin must be clear of any obstacles on startup. so if it's hitting the glass at startup it's probably going into error mode.
I've done the update and deleted the "M307 H3 A-1 C-1 D-1", and everything seems to work.
But I have been looking to see how the bed compensation works because my printing surface is very big (1 000 x 1 200mm). I've adjusted it manually has good as I could but it is not sufficient.
The printer has got 2 separate Z-axis, one each side. And a moving Y platform. It's a cartesian printer.
It might be very simple but I can't seem to understand it
. What codes do I need to send so I can print something with the bed compensation?
why are you adjusting the result of the bltouch probing?
depends, if you want to probe before printing G29
if you want to reload previous results G29 S1the G29 needs be be after the G28
@Veti I adjusted the bed manually to have it as accurate as I could so the printer doesn't have to compensate too much.
I've done the G28 then the G29 but after that, the only thing that I can do is see the heightmap on the DWC. But how do I load the heightmap into a file with a model in it so it can adjust the height automatically when printing?
What does G32 do?
g29 enables the compensation.
check with m122What does G32 do?
if you have more than 1 z motor see
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors -
I have now figured everything out thanks to all of your support and help.
Thank you very much for replying quickly and for your time
Have a good daySincerely George
