    Hot swapping extruder motor (Nema 17 1.6A)
    • DuetUserundefined
      DuetUser
      Is there any remote possibility of swapping extruder motor without turning off the printer.
      If the steppers are released and there would be a switch on motor cable cutting it off, would it be safe to disconnect it and reconnect?
      I was doing it illegaly with Nema 8 a couple of times and nothing bad has happened, but could it be made a safe, repeatable operation?
      Peter
      peter
      • theruttmeisterundefined
        theruttmeister
        So long as you turn off the driver, there's no issue with doing that.
        You might get some error messages as the drivers detect that nothing is connected, but those can just be ignored.
        Isolate, substitute, verify.
          Phaedrux Moderator @theruttmeister
          @theruttmeister said in Hot swapping extruder motor (Nema 17 1.6A):
          Or as part of your disconnect macro you can disable the driver entirely with M569 R-1 P#, where # is for that driver.
