    Z Homing + Plus Z Probe
    • Adamfilipundefined
      Adamfilip
      I want to use a Z homing switch (Optical) and also a Touch-Mi Probe
      The Z homing switch is for general homing and the Zprobe is for Mesh Point creation.
      Which P Settings should I use for M558 to accomplish this?
      M558
      The way my machine is setup, the machine needs to home first in order to accurate move to the magnet deploy position for the Touch-Mi, as the deploy magnet is fixed to the frame of the machine.
        The z endstop is defined with M574 and called with a G1 H1 Z move.
        The probe is defined with M558 and G31/M557 and called with G30/G29.
        Both can be used independently. However, before using G29 you should use the probe to define Z0 at the center of the bed with G30.
