    Duet2 Wifi+Duex5 and SBC
    Firmware installation
    612
    • taconite
      taconite last edited by
      Hey guys,
      as this topic is a little flooded (https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc) I would just like to get things straight.
      To get the setup Duet2 Wifi + duex5 + SBC to work I need to do the following
      1. Attach 1 of deadwood83's boards to the duet wifi
      2. Connect the Pi and the Duet with a weird old ethernet cable (for the twisted pairs)
      3. Put DSF on the Pi (Version 3.2.0) and put the SD card into the PI
      4. configure the Pi as in SBC Setup for Duet3 (https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3)
      5. Bossa RRF 3.2 (Duet2Firmware_SBC.bin) onto the due2 wifi.
      6. Don't have a config on the SD-card of the duet or no SD-card at all
      7. Run it and have fun
      Anything I missed?
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      wilriker 1 Reply Last reply Reply Quote 0
      • taconite
        @deadwood83 @bearer @wilriker could you please assist šŸ™‚
        Custom ANET A8
        • wilriker
          wilriker Moderator @taconite last edited by
          @taconite Your list looks complete to me.
          Re #2: Depending on the length of your connection between D2 and Pi you don't need twisted pair (I use ordinary straight jumper wires and even running four 4-wire stepper cablings across it didn't have an influence). But of course better wiring never hurts.
          Re #6: do not insert the SD card.
          Manuel
          My Tool Collection
          • taconite
            @wilriker thank you for your reply! Do I need to do something special for the SPI Pins on the WiFi ESP?
            #2 alright than I will try both and see what the difference will be
            #6 alright!
            Custom ANET A8
            • taconite
              So I made the initial setup according to the list. Pi (Pi 3B+) is working but I don't get a connection to the duet: "failed to connect to duet3" Please check your connection (DCS is not started).
              the cable is setup like: duet --> SBC
              CS --> pin 24
              RDC --> pin 22
              3,3V --> pin 17
              MISO --> pin 21
              MOSI --> pin 19
              SCK --> pin 23
              GND --> pin 20
              There is no SD-card in the duet.
              Duet2 Wifi is connected via USB to Laptop
              Pi has its own power supply
              Any ideas how to troubleshoot?
              Custom ANET A8
              • wilriker
                wilriker Moderator @taconite last edited by wilriker
                @taconite I don't know what RDC pin is (EDIT: I guess that's a typo and actually refers to the TfrRdy Pin) but I miss Transfer Ready pin that is (in default configuration) connected to pin 25 of RPi.
                EDIT: I found that in my setup it was absolutely necessary to have an addition ground connection between the RPi and the PSU that delivers VIN to Duet. As you are still working with power from USB that's not critical yet, but keep that in mind.
                Manuel
                My Tool Collection
                • taconite
                  taconite last edited by taconite
                  @wilriker you are absolutely right - it was a typo. it should be RDY.
                  mhh okay that is weird - I didn't find a 100% info about the wiring so I searched it together from here (https://forum.duet3d.com/topic/17241/quest-duet2wifi-sbc-without-espectomy-possible-yes/2)
                  EDIT: mhh pictures are not uploading
                  and here (https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc)
                  ![0_1612471698173_wire2.PNG](Uploading 100%)
                  EDIT: thank you for the grounding info. that's gonna be a little problematic because for the test setup I am powering the pi with a Pi power supply (micro USB) but I will find a solution for that.
                  Custom ANET A8
                  • wilriker
                    @taconite My fault. I was mixing up RPi pin numbering schemes. I meant GPIO 25 which is physical pin 22. So that's actually correct on your end already.
                    Too tired right now for good ideas, sorry.
                    Re ground connection: it's totally sufficient to connect any one of the ground pins of RPi's GPIO header to ground of your PSU. While testing I even powered the Duet from one of the USB ports of the RPi. Worked fine. Only when I eventually applied 24V VIN to the Duet it was that I required this extra connection for stable communication.
                    Manuel
                    My Tool Collection
                    • taconite
                      @wilriker alright! Than get a good night of sleep šŸ˜‰
                      I would really appreciate if you could come back tomorrow with some fresh ideas šŸŽÆ haha
                      Maybe with an idea how i could diagnose a possible error. To narrow it down why it is not connecting.
                      Custom ANET A8
                      • A Former User
                        A Former User last edited by
                        logging in via ssh to see why dcs isn't starting would be a a good start, see systemctl status duetcontrolserver.service and/or journalctl -xeu duetcontrolserver.service for details.
                        To troubeshoot the spi stuff maybe search for "loopback" to see an old thread troubleshooting a faulty raspberry pi
                        • taconite
                          @bearer
                          - journalctl -xeu duetcontrolserver.service
                          -- Automatic restarting of the unit duetcontrolserver.service has been scheduled
                          -- the configured Restart= setting for the unit.
                          Feb 05 17:24:24 duet3 systemd[1]: Stopped Duet Control Server.
                          -- Subject: A stop job for unit duetcontrolserver.service has finished
                          -- Defined-By: systemd
                          -- Support: https://www.debian.org/support
                          -- A stop job for unit duetcontrolserver.service has finished.
                          -- The job identifier is 12641 and the job result is done.
                          Feb 05 17:24:24 duet3 systemd[1]: Starting Duet Control Server...
                          -- Subject: A start job for unit duetcontrolserver.service has begun execution
                          -- A start job for unit duetcontrolserver.service has begun execution.
                          -- The job identifier is 12641.
                          Feb 05 17:24:25 duet3 DuetControlServer[4176]: Duet Control Server v3.2.0
                          Feb 05 17:24:25 duet3 DuetControlServer[4176]: Written by Christian Hammacher fo
                          Feb 05 17:24:25 duet3 DuetControlServer[4176]: Licensed under the terms of the G
                          Feb 05 17:24:26 duet3 DuetControlServer[4176]: [info] Settings loaded
                          Feb 05 17:24:27 duet3 DuetControlServer[4176]: [info] Environment initialized
                           ESCOC
                          controlserver.service has been scheduled, as the result for
                          he unit.
                          rt
                          ob result is done.
                          rt
                          4176]: Written by Christian Hammacher for Duet3D
                          4176]: Licensed under the terms of the GNU Public License Version 3
                           ESCOD
                           ESCOD
                           ESCOD
                           ESCOD
                           ESCOD
                          -- The job identifier is 12580 and the job result is done.
                          Feb 05 17:24:21 duet3 systemd[1]: Starting Duet Control Server...
                          -- The unit duetcontrolserver.service has entered the 'failed' state with result
                          Feb 05 17:24:01 duet3 systemd[1]: Failed to start Duet Control Server.
                          -- Subject: A start job for unit duetcontrolserver.service has failed
                          -- A start job for unit duetcontrolserver.service has finished with a failure.
                          -- The job identifier is 12153 and the job result is failed.
                          Feb 05 17:24:01 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
                          Feb 05 17:24:01 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
                          -- Subject: Automatic restarting of a unit has been scheduled
                          Feb 05 17:24:01 duet3 systemd[1]: Stopped Duet Control Server.
                          lines 3310-3332/3657 91%
                          -- The unit duetcontrolserver.service has entered the 'failed' state with result 'protocol'.
                          Feb 05 17:24:01 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
                          Feb 05 17:24:01 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 181.
                          -- Automatic restarting of the unit duetcontrolserver.service has been scheduled, as the result for
                          -- The job identifier is 12214 and the job result is done.
                          Feb 05 17:24:01 duet3 systemd[1]: Starting Duet Control Server...
                          -- The job identifier is 12214.
                          Feb 05 17:24:02 duet3 DuetControlServer[4086]: Duet Control Server v3.2.0
                          Feb 05 17:24:02 duet3 DuetControlServer[4086]: Written by Christian Hammacher for Duet3D
                          Feb 05 17:24:02 duet3 DuetControlServer[4086]: Licensed under the terms of the GNU Public License Version 3
                          Feb 05 17:24:03 duet3 DuetControlServer[4086]: [info] Settings loaded
                          Feb 05 17:24:03 duet3 DuetControlServer[4086]: [info] Environment initialized
                          Feb 05 17:24:04 duet3 DuetControlServer[4086]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                          Feb 05 17:24:04 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'protocol'.
                          -- Subject: Unit failed
                          Feb 05 17:24:04 duet3 systemd[1]: Failed to start Duet Control Server.
                          lines 3310-3358/3657 92%
                          Custom ANET A8
                          A Former User 1 Reply Last reply Reply Quote 0
                          • taconite
                            ā— duetcontrolserver.service - Duet Control Server
                               Loaded: loaded (/lib/systemd/system/duetcontrolserver.service; enabled; vendo
                               Active: activating (start) since Fri 2021-02-05 17:23:47 CET; 1s ago
                             Main PID: 4023 (DuetControlServ)
                                Tasks: 9 (limit: 2063)
                               CGroup: /system.slice/duetcontrolserver.service
                                       └─4023 /opt/dsf/bin/DuetControlServer
                            Feb 05 17:23:47 duet3 systemd[1]: Starting Duet Control Server...
                            Feb 05 17:23:48 duet3 DuetControlServer[4023]: Duet Control Server v3.2.0
                            Feb 05 17:23:48 duet3 DuetControlServer[4023]: Written by Christian Hammacher fo
                            Feb 05 17:23:48 duet3 DuetControlServer[4023]: Licensed under the terms of the G
                            so there is not a lot of info ...
                            Custom ANET A8
                            • A Former User
                              A Former User @taconite last edited by
                              @taconite said in Duet2 Wifi+Duex5 and SBC:
                              this suggest the trf_rdy pin isn't wired/working correctly.
                              (also please put three backticks (```) over and under long text like that to preserve formatting next time, or use the code formatting button on the toolbar (between strikeout and link))
                              • taconite
                                So I rechecked the wiring and the board itself - didn't find any issues. Reflashed the SBC firmware to the Duet and it seems that now I get a connection even though it is not really stable. BTW the Duex5 is not connected right now
                                Feb 06 13:54:07 duet3 DuetControlServer[5480]: [warn] RepRapFirmware got a bad header checksum
                                Feb 06 13:54:07 duet3 DuetControlServer[5480]: [warn] Restarting transfer because the number of maximum retries has been exceeded
                                Feb 06 13:54:07 duet3 DuetControlServer[5480]: [warn] Bad header CRC32 (expected 0x00000000, got 0x59923eca)
                                Feb 06 13:54:07 duet3 DuetControlServer[5480]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000000)
                                Feb 06 13:54:07 duet3 DuetControlServer[5480]: [info] Connection to Duet established
                                Feb 06 13:54:08 duet3 DuetControlServer[5480]: [warn] Lost connection to Duet (Board is not available (no header))
                                EDIT: So it's more like a "connection" šŸ˜„ I can reach it over the network and I uploaded a valid config but its not responsive at all
                                Custom ANET A8
                                  Can you provide a photo of the wiring between the Duet and the Pi?
                                  • A Former User
                                    Verify RRF and DSF versions are compatible, if they are, odds are the connection is the issue given the checksum/crc issues.
                                    How is the common ground between the duet and sbc?
                                    Have you tried lowering the SPI frequency? (Edit there is a json config file under /opt/dsf on the sbc
                                    • taconite
                                      @bearer
                                      I got DuetPI (With GUI form here):
                                      RRF is 3.2.0
                                      I will provide Pictures of the common ground and the wiring in a minute. (maybe I should increase the gauge of the common ground)
                                      No I didn't change the SPI speed but I could try to
                                      EDIT: The black single cable is the common ground
                                      Custom ANET A8
                                      • A Former User
                                        The little pcb has a pad labeled gnd1, this also carries a common ground from the duet to the sbc?
                                        and the shield is grounded at both ends? if the shield is the ground connection thats not optimal either, ground the shield at one end and use a conductor for signal ground
                                        the cable also seems a bit long in the tooth, reducing the spi frequency might help if the length is the issue.
                                        /opt/dsf/conf/config.conf and reduce the "SpiFrequency": 8000000, to maybe 2mhz or even less
                                        • taconite
                                          Yes the GND1 of the little PCB from @deadwood83 has a connection to the GND of the Duet and the SBC
                                          So what I did:
                                          1. Removed the Shield from one side
                                          2. connected the GND1 pin of the little PCB with an extra cable to the GND of the SBC
                                          3. reduced the spifrequency to 2 MHz.
                                            --> same thing as before
                                          What do you mean with "bit long in the tooth"
                                          Custom ANET A8
                                            The Duet to Pi cable is way too long. Also, as it is a round cable, it will have higher capacitance and more crosstalk than a ribbon cable would. You should replace it by a short (150mm or less) ribbon cable.
                                            • taconite
                                              Changed to a short ribbon cable - nothing changed - still "no header" fault message
                                              Custom ANET A8
                                              • taconite
                                                maybe I should try the duetpi-lite?
                                                Custom ANET A8
                                                • taconite
                                                  @dc42 Sorry for bothering you again. Do you any other ideas?
                                                  Custom ANET A8
                                                  • wilriker
                                                    wilriker Moderator last edited by
                                                    Sorry for not getting back to you earlier. DuetPi-lite won't make a difference.
                                                    Can you please run DuetControlServer from command-line with -l debug to use debug log level and post the output? Former output posted here did not contain enough information.
                                                    Manuel
                                                    My Tool Collection
                                                    taconite 1 Reply Last reply Reply Quote 1
                                                    • taconite
                                                      taconite @wilriker last edited by
                                                      @wilriker said in Duet2 Wifi+Duex5 and SBC:
                                                      No problem at all! Don't feel sorry - every help is appreciated!
                                                      With what command line exacly? Sorry I am a bit of a noob with RPi and Shell
                                                      Custom ANET A8
