    HomeZ with sensor
    71
    • pcsentinel
      pcsentinel last edited by
      Can anyone tell me if during a home z operation with a sensor you should turn off compensation before sensing. Should you use G29 S2 or not?
      i.e.
      G28 XYU ; Home X
      G91   ; relative mode
      G1 H2 Z5 F1800 ; raise head 4mm to ensure it is above the Z probe trigger height
      G90   ; back to absolute mode
      G1 X155 Y160 F10000 ; move to bed centre for probing
      ;G29 S2
      G30 ; probe the bed and set Z height
      ;G29 S1
      • fcwilt
        fcwilt last edited by
        I always have.
        I only load the height map at the start of a print.
        And I unload it at the end of the print.
        • Veti
          Veti last edited by
          no you need to establish z=0 (G30) before loading a heightmap
          pcsentinel 1 Reply Last reply Reply Quote 0
          • pcsentinel
            pcsentinel @Veti last edited by
            @Veti
            Hi, that's what the code does,
            • Veti
              Veti last edited by
              homing unloads the height map.
              fcwilt 1 Reply Last reply Reply Quote 0
              • fcwilt
                fcwilt @Veti last edited by fcwilt
                @Veti said in HomeZ with sensor:
                I know that has changed in the past so I checked it just to be safe - this was with firmware 3.1.1 AND 3.2.0
                I executed G29 S1 and verified with the DWC that mesh compensation was in use.
                Then I executed:
                • G90 G1 Z25 F600 ; to be sure the end stop sensors were not triggered
                • G91 G1 H1 Z-30 F300 ; one slow speed homing move
                I checked via the DWC and mesh compensation was still in use.
                • Veti
                  Veti last edited by
                  try a G28 Z. that has a different meaning
                  fcwilt 2 Replies Last reply Reply Quote 0
                  • fcwilt
                    Will do.
                    • fcwilt
                      OK I renamed my existing homeZ.g file and created a new one just with:
                      G90
                      G1 H2 Z25 F600
                      G91
                      G1 H1 Z-30 F300
                      G90
                      Same result. The DWC reported mesh compensation was still in use.
                      Glad to do more tests.
                      • Veti
                        Veti last edited by
                        maybe i got it confused with marlin
                        • fcwilt
                          I have trouble keeping things straight as the "side effects" of various commands have changed over time.
                          So I now just do everything explicitly in my code.
                          • Veti
                            Veti last edited by
                            but thinking about it.
                            even if you are rehoming and an offset would be applied. the point where you homed should be 0 anyway
                            • pcsentinel
                              Hi, just coming back to the original point,
                              are you saying that I don't need to use G29 S2 and G29 S1 as that is already explicit in the Home functionality?
                              • fcwilt
                                fcwilt @pcsentinel last edited by
                                @pcsentinel said in HomeZ with sensor:
                                You may still need to use G29 S1 and G29 S2.
                                I tested firmware 3.1.1 and homing does not affect the state of mesh compensation. I will test 3.2 if that applies to you.
                                The "side effects of certain commands have changed over time BUT it is always safe to do things explicitly rather than depend on "side effects".
                                The worse that happens is you issue a command that is redundant.
                                  I think it would be best practice to clear any bed transformations before trying to reset Z0 with homing or doing a G29, etc.
