Delta calibrate x and y too small on calibration cube 20mm
To whom it may concern,
HELP PLEASE.
I have been calibrating my Anycubic Predator Delta for a few days now, Fun stuff.
I have the Hayden Mag ball arms and a smart effector with a e3d hot end.
Found the trigger height, auto calibration 6 point and made a bed file.I have successfully printed a few calibration cubes first the wall thickness was too much so I followed the youtube way of fixing the steps in cura and it is almost bang on .4mm walls very pleased, However the actual cube dimension are off.
The y is 18.20
x is 18.12
z = 20mmHow to fix I put in the rod length as the mag arms come with a sticker 440.47.
Let auto calibrate do the radius after a rough measurement.The prints are okay however I need way better dimensional accuracy Please help solve this.
Kind regards,
Grant.
@gmang73 said in Delta calibrate x and y too small on calibration cube 20mm:
The y is 18.20
x is 18.12this is to much.
there must be a wrong setting somewhere.post your config and overwrite
also the bed.g
Config.g
; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 29 2021 08:44:52 GMT+1000 (Australian Eastern Standard Time); General preferences
M550 P"ANYCUBIC PREDATOR" ; set printer name
M665 R219.292 L440.470 H418.938 B185.0 x0 y0 z0 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X-0.42 Y0.17 Z0.25 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80 Y80 Z80 E415 ; set steps per mm
M566 X3000 Y3000 Z3000 E3000 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z12000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X9000.00 Y9000.00 Z9000.00 E6000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 p"zstop" ; configure Z-probe endstop for high end on Z; Z-Probe
M558 P5 R0.4 C"zprobe.in+zprobe.mod" H3 F500 T6000 ; set Z probe type to effector and the dive height + speeds
G31 P50 X0 Y0 Z-0.16 ; set Z probe trigger value, offset and trigger height
M557 R85 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossConfig override
; config-override.g file generated in response to M500 at 2021-02-07 15:04
; Delta parameters
M665 L440.470:440.470:440.470 R219.130 H418.830 B185.0 X-0.238 Y0.447 Z0.000
M666 X-0.458 Y0.127 Z0.331 A0.00 B0.00
; Heater model parameters
M307 H0 R0.382 C272.644:272.644 D1.13 S1.00 V23.5 B0
M307 H1 R6.558 C203.782:203.782 D3.99 S1.00 V23.8 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00
M486 S-1
and your bed.g
; bed.g
; called to perform automatic delta calibration via G32
; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 29 2021 08:44:51 GMT+1000 (Australian Eastern Standard Time)
; home all towers
; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
; bed.g file for RepRapFirmware, generated by Escher3D calculator
; 10 points, 6 factors, probing radius: 150, probe offset (0, 0)
; 13 points, 6 factors, probing radius: 150, probe offset (0, 0)
; 13 points, 6 factors, probing radius: 80, probe offset (0, 0)
G30 P0 X0.00 Y80.00 Z-99999 H0
G30 P1 X69.28 Y40.00 Z-99999 H0
G30 P2 X69.28 Y-40.00 Z-99999 H0
G30 P3 X0.00 Y-80.00 Z-99999 H0
G30 P4 X-69.28 Y-40.00 Z-99999 H0
G30 P5 X-69.28 Y40.00 Z-99999 H0
G30 P6 X0.00 Y40.00 Z-99999 H0
G30 P7 X34.64 Y20.00 Z-99999 H0
G30 P8 X34.64 Y-20.00 Z-99999 H0
G30 P9 X0.00 Y-40.00 Z-99999 H0
G30 P10 X-34.64 Y-20.00 Z-99999 H0
G30 P11 X-34.64 Y20.00 Z-99999 H0
G30 P12 X0 Y0 Z-99999 S6
g29 s2
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
g29 s2
remove that. that makes no sense here.
just for testing change the S6 to S9 and run the auto calibration and post the output
G29
Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
61 points probed, min error 0.103, max error 0.617, mean 0.356, deviation 0.095
Height map saved to file 0:/sys/heightmap.csv
07/02/2021, 4:40:22 pm G32
Calibrated 9 factors using 13 points, (mean, deviation) before (0.353, 0.120) after (1.120, 0.068)
you want to run G30 before G29
post the new M666 and M667 after the G32
This post is deleted!
07/02/2021, 4:53:06 pm G29
61 points probed, min error -0.096, max error 0.086, mean -0.008, deviation 0.038
07/02/2021, 4:51:55 pm G32
Calibrated 9 factors using 13 points, (mean, deviation) before (-0.020, 0.031) after (0.000, 0.028)
